kettal
Banned
Why not build more hockey rinks at CNE grounds, you know that place with thousands of empty parking spots all winter long?
Unfortunately, hockey arenas need parking..
Ever heard of UNDERGROUND PARKING!!!!!!!!!!!!!!!!!!!!!!!
Do you know how big of an underground facility you would need for 400+ parking spots? how does that compare to other underground facilities in the city? And yes, you need that many spots. Looking at 4-pad rinks across the province, most have at the very least 350 spots.
Before you go trying to attract as much attention as possible to yourself, you should probably consider the logistics and feasibility of such a project. As Glen mentions it would be a very expensive endeavour. Considering the immense need for arenas in this city, I wouldn't want to propose anything that puts the project in jeopardy.
I think the real problem here is why 4 rinks ... that's common place out in the suburbs but do we really need that here. If you look at the model the old city took, they built many ice rinks (but just 1) and they're close by. As opposed to the model adopted by most suburbs i.e. build 4+ in one location and have them located a lot further apart.
Money and politics.....
but question is.. is there that much demand by the lower don lands to fill up 4 hockey arenas?
I guess they think there will be once the new condos are built?
Your answer:Then why not disperse those hockey rinks and their parking lots all over the city!
4 rinks are more efficient than 1 or 2, simply put. You only need 1/4 of the maintenance staff, 1 zamboni (although most 4-pads have 2, but I've played in ones with only 1. Just makes scheduling tighter) and I wouldn't doubt that the cost to keep a 4 pad cold is cheaper than a 1 or 2 pad. Also, if there's the space here for 4 rinks, then you want to make the most of it. Why limit the amount of recreation space? If there was enough room for 4 soccer fields, we wouldn't build 2. Also, 4 pads provide far greater flexibility. You can host a fairly good size tournament (re: make money) and still have 1 rink available for alternative uses. And, ultimately, we need 4. There's a huge need for arenas in Toronto and Ontario as a whole. Most communities only have about 50% of what they need to meet demand from my experience.
