AlvinofDiaspar
Moderator
To me, it's a no-brainer that the Leaside side of the tracks option is the best.
Site 1 (Wicksteed) would have worked better - with the added bonus of not having a MSF taking up station proximate land.
I have read those slides yes. Other than the two I mentioned which others do you think could work well?Actually if you have read the slidedeck, at least some of the other choices would have worked (taken at their face-value). The reason they chose this site is ultimately that they didn't think demolishing a good chunk of the community core a more serious negative than the other negatives.
I mean they're using part of Wicksteed so I didn't think too much of it but I agree they could most likely shift a lot of the storage tracks out that way no problem, and that would spare a lot of the Thorncliffe businesses. The only problem I see is not having enough room without heavily disrupting the roads there.Site 1 (Wicksteed) would have worked better - with the added bonus of not having a MSF taking up station proximate land.
That is the other option that makes sense to me, aside from the fact that I thought Wickstead had the potential to impact environmentally sensitive land.Site 1 (Wicksteed) would have worked better - with the added bonus of not having a MSF taking up station proximate land.
The other factor is that it is much cheaper and easier to re-locate low-density commercial than specialized industrial. There is plenty of parking lot space nearby that can be built on to provide new homes for those businesses, if you try and re-locate the industrial businesses, they are likely moving very far away and those jobs are gone for locals.I mean they're using part of Wicksteed so I didn't think too much of it but I agree they could most likely shift a lot of the storage tracks out that way no problem, and that would spare a lot of the Thorncliffe businesses. The only problem I see is not having enough room without heavily disrupting the roads there.
Also, on the opposite side of the tracks from the station is not proximate from an actual transit-use perspective.
Local enough that if they had to move their current employees would probably be too far from their new location.Those jobs probably aren't local if they are specialized.
If they had chosen one of the other viable alternatives, people would be moaning about the loss of local employment due to displaced businesses.
I'm referring to how the facilities are likely specialized. The labour is likely a mix of low-skill and high-skill depending on what they produce.Those jobs probably aren't local if they are specialized.
Site one is the Tremco factory.
Tremco makes commercial and industrial roofing products, sealants, caulking and waterproofing. They've been on that site for 60 years.
Politically that would be very hard to move.
A few years ago the TRCA literally moved the West Don River so their site wouldn't fall into the Don Valley. (and re-graded the slope).
Move the river, shutter the factory.........Bad Look.
Jobs aside (though Tremco does provide 190 of those); that's Industrial land paying commercial tax rates, that's a lot of coin out of the Cities coffers.
You could say the same for storefronts with the current plan. I agree moving commercial space is probably more harmful to the community but it's not like there's no space. I mean half the neighbourhood is parking lots.Then pay them to relocate somewhere local - I am sure the province (and the city) have enough vacant industrial land to make that possibility
Community core is a stretch. From the images, they've provided it looks like the closest thing to Overlea is a power substation set back a minimum of 30 metres away from the street. If you're counting the core as south of Overlea then it doesn't meet this definition. Mind you this "core" directly south of Overlea is a sea of mall parking lots. Not exactly a community hub. They've done a relatively good job at keeping the facility far from actual residences, so as long as they can do a good job of integrating the facility in with the rest of the community, and hopefully allowing structures to be built on top of it, it's not infringing on the neighbourhood too much minus the forced relocation of businesses.Like I have said, they didn't think demolishing a good chunk of the community core a more serious negative than the other negatives.
