I will post this here as well cross post elsewhere as it has to do with elevated systems. This based on a report problems pertaining to
Hawaii LRT which is a light metro that is years late and over budget that was just reported on.
One also needs to look at Montreal REM issues as well.
The person lives in Vancouver and a transit advocate makes this comment.
This isn't an issue exclusive with Light Metro and can happen with literally any mode. Heavy rail, we have trains running on TTC gauge like our own subway, as well as the Lagos Metro that is literally buying off our old rolling stock. We have Metros with Rubber Tyres, Metros with tight curves that require absolutely tiny segments (Chicago). There are also a ton of gadgetbahn type metros around the world that try to do their own thing. The term "Light Metro" isn't a specifier of technology, all it is is a specification of service type, which is fully grade separated rail service that usually runs lower capacity rolling stock usually in exchange for supporting higher frequencies. How this is done is mostly up to the manufacturer, and the type of technology you use to run your light metro is just that, a choice of technology. Some cities like Vancouver invested into this new and up and coming ICTS technology, which is definitely strange and bespoke, but there are many systems around the world that use it so to say it will be abandoned anytime soon is baseless fearmongering.
Looking at what's happening in Honolulu, its difficult to call that a unique issue with Light Metros. Instead this just looks like another list in a long list of incompetent decisions done by the design and engineering team. If we are going to look at cities that mess up transit and point out their failures as proof that a certain type of mode or service type can't work, we can be here all day. "LRT is bad and prone to endless problems - just look at what happened in Ottawa!"
Now let's read through what this guy from Vancouver has to say:
Here we have the big problem with light metro. Unlike modern light rail, which is modular and interchangeable and flexible, light metro tends to be proprietary, as one company's light metro is not designed for another company's light metro
Unless you're using a bespoke technology, no not really, and its hard to say LRT is any way more compatible. Even in the realms of LRT you often have major differences between cities ranging anywhere between different railway gauges to odd loading gauges, and in many cases you still have newer LRT systems like in Sydney that use conduit electrification.
Now ALRT cars can operate on ART tracks and visa versa, they cannot operate with each other in coupled sets and as the ART cars have longer and larger trucks/bogies, they have great difficulty with the switches or points on the ALRT Expo Line; the cars must travel through the switches at a low speed and there is is much protest and flange squeal when they do.
Except they do and they have for a long time. Before 2016, the Millenium line was just a looping branch of the Expo Line, so all of these coupled sets ran on most of the length of the Expo Line without any issues, and coupled sets still run on the Expo Line proper.
Alstom now owns the proprietary light metro system now called Movia Automatic Light Metro and Translink is more than worried that they will dump the system altogether as no one else, except Vancouver wants the damn thing.
Extremely unlikely. There are still many cities in the world that use this technology, including the NYC Airtrain, the Beijing Airport Express, a good chunk of the Kuala Lumpur metro system, and several more in Japan. ICTS isn't going to be dropped as a supported technology any time soon.
The Canada Line needs a $1.5 to $2 billion rehab, just to increase its capacity beyond 9,000 pphpd and this must be done before any expansion of the line is considered.
[Citation Needed]
TransLink is well aware of this but at this point they do not want to shock the taxpayers with bad news until their $4.6 billion, 12.8 km extensions of the Expo and Millennium Lines are well under way and i will add this, for $4.6 billion, not a car will be taken off the road.
TransLink is "well aware" of this, which is why they and the NDP just released their 2050 transit plan, with the main plan involving building a ton of new skytrain lines and extensions.
Also, the Broadway subway won't get a single car off the road? Massive claims with more citations needed.
Even if that was true, the primary goal of the Broadway subway is to relieve the 99-Bline, which is the busiest bus route in both the US and Canada, that, alongside the fact that its the first phase of an extension to the biggest university in the province, and will connect the main skytrain system with the Canada Line outside of Waterfront adding far more redundancy to the Skytain network.
I really have to question this source's background and claims.
