 1.3K     0
 1.1K     1
 393     0
Again, those are both route maps. Actually only a small part of the route map.
The example given originally was of the system map being LCD - which would require a much bigger screen. It's this I was curious about who is doing.
Well there's no point in showing the whole system map on LCD, because, the reason they do it on LED is likely the rolling stocks are shared amongst the lines.
It is usually...
A) LCD displays portion of the route, or the entire route (if it's possible) . Affix a map of the complete network somewhere else in the train.
B) LED shows the whole network, or majority of the network.
The only place where the TTC currently runs buses along a subway line is at the north end of Yonge St., where the stops are farther apart.
TTC runs buses all day along Sheppard subway and the northern section of Yonge. At peak hours, buses run along all of Yonge.
The TTC is concerned with subsidence caused by the TBMs underneath the active subway lines. At both Allen Rd. and Yonge, the TBMs will be removed and relaunched at the ends of the station box, with the rest of the structure being built by cut-and-cover.
Metrolinx announced Enter the Tunnel Boring Machines Naming Contest! at this link.
Submit an entry for the Tunnel Boring Machines (TBMs) Naming Contest for a chance to put your personal stamp on one of the biggest transit expansion projects in Toronto’s history.
By the end of 2012, four 10.5-metre, 500-tonne TBMs will be delivered in Toronto. These TBMs will dig the tunnel underneath Eglinton Avenue for The Crosstown Light Rail Transit line. Four machines with such an important job deserve proper names, and we need your help naming them. Visit our contest page to enter.
There's a math question to answer so you can enter.
I bet if you were to do a poll, a good chunk or even half of Torontonians don't even believe the line will eventually be built. They have to expect this feudal battles with the only end result being another study.
You may have to walk a few blocks from Oakwood and Eglinton to the nearest Crosstown LRT station at either Allen Road or Dufferin, if you don't board the Ossington bus.
From insidetoronto.com, at this link.
Eglinton LRT: Future of Oakwood station murky
York Guardian by Rahul Gupta
A senior Metrolinx official has retracted statements he made at a public meeting this week, which indicated the transit planning agency had ruled out adding an Oakwood Avenue stop to the station map for the Eglinton-Scarborough Crosstown light rail transit line.
Responding to a question from resident Claudia Giraldo, Jamie Robinson, director of community relations for rapid transit implementation, said on Oct. 22 that adding Oakwood to the planned list of stations was unlikely to happen.
He later confirmed his remarks following the town hall meeting at the North Toronto Memorial Community Centre. The evening had been organized by St. Paul’s Councillor Josh Matlow.
“What we’ve said is we’ll proceed as if Oakwood will be there, but at this particular point in time Oakwood will not be one of the stations included,†said Robinson on Monday evening.
But on Tuesday morning Robinson retracted that statement and stressed no final decision has yet been made on the fate of Oakwood.
“I did misspeak to some extent,†said Robinson who blamed his error on his lack of familiarity with the issue stemming from being in his current position for only two months.
The planned installation of station headwalls, a series of concrete support columns underneath Eglinton Avenue, at the east and west side of each planned station location, including Oakwood, would theoretically make it possible to build the stop if approved.
Getting Oakwood onto the list of planned LRT stations, however, would require amending the existing environmental assessment which would require additional approval from the province’s ministry of the environment.
Such a process might also require a further public consultation on the idea depending on whether the amendment is deemed “significantâ€, said Robinson.
Robinson said no EA amendment is planned at the moment, but that decision could be re-considered in the next few months.
Further hurting Oakwood’s candidacy for inclusion is its relative proximity to the planned stations - Dufferin in the west and Eglinton West station (at Allen Road) in the east - as well as the desire of Metrolinx to locate efficiencies to reduce costs related to construction of the Crosstown, said Robinson.
“When we look station-by-station Oakwood would have lower ridership and it’s fairly close to other stations in the area,†said Robinson.
There has been vocal community support for an Oakwood stop of late
A petition brought forth by local city councillor Josh Colle earlier in the year has gained signatures of support from 400 residents as of July.
In August, Colle said a stop at Oakwood Avenue was “50 per cent closer†to reality.
“We’re going to keep pushing, but it’s good to hear they’re at least clearing the path so to speak to make sure an Oakwood Station is possible,†said the representative for Eglinton-Lawrence.
"An EA amendment to add Oakwood would need to be completed by late 2014, when station construction is slated to begin,†said Robinson.
The Eglinton Crosstown LRT is scheduled to begin running in 2020.
I always thought Oakwood was superfluous, since it is reasonably walkable to Eglinton West or Dufferin and also a short bus ride on the 63 for those who can't hack the 400 m walk.
Also, just looking at the block layouts, the network buffer distance is such that Oakwood would be of limited use to anybody not actually wanting to go to exactly the corner of Oakwood and Eglinton. Block lengths between Times Road and Marlee are roughly 300 meters, so somebody living mid-block on a parallel sidestreet like Livingstone wouldn't save that much time wrapping around the corner to get to Oakwood station. Plus, Eglinton West has better network connectivity, being the intersection of two rapid transit lines, and this usually compels people to walk slightly further distances. I think that an Oakwood station would only give a decisive advantage to somebody who lived in the area heading west, but that's probably a pretty small number of people and not worth lavishing $50-100 million and bumping back the EA/construction schedule for.
While Oakwood may not be needed, since when was it ever not approved? As far as I can recall it has been just as much on the list as the other stations.
So... There would need to be a bus between Keele and Dufferin since there's only one station between them which is a longer walk. Run the bus from Eglinton West on the west side.
Rather than running a spur route, there's nothing stopping the TTC from making a branch of the Keele bus run along Eglinton to say Eglinton West Station. That way it covers the 'gap' in coverage. But I'm sure stuff like that will be ironed out later on.
There is to be at station for the Barrie Line, but that still a fair walk between it and Dufferin.
The density is not there to support a station between the 2.
The Caledonia station is NOT located at Caledonia Road. The Caledonia station is located between the entrance ramps to the Westside Shopping Centre and just west of the railway overpass, about three blocks west of Caledonia. The bus loop would be at Croham Road (east of the railway) for the 47B & 47C Lansdowne buses, which BOTH northbound and southbound buses would use and travel along Eglinton Avenue West, to reach. The main entrance would be at Croham Road and a secondary entrance at Westside Shopping Centre.
You can download the Caledonia presentation in PDF form from this link.
