innsertnamehere
sheppard was at 2,900 I thought with finch being closer to 2,600. Eglinton surface portion would be at 3,600, underground at 5,900 and Scarborough with 8,000 on the LRT or 9,500 with the current subway plan.
Paint some bus lanes on Sheppard East from Don Mills Station to Meadowvale and call it a day. Your obsession with the SELRT (which is overkill) is very disturbing![]()
Support a SEBRT like UT member Gweed!!!!!
Finch was between 2,300 and 2,800 [EA]. I seem to remember Sheppard being 4,000, but I may be getting that number confused with the Sheppard East Subway. Either way, both have more than enough usage on day one for LRT because of the lower cost to operate the LRT and because the LRT will allow for more ridership growth (BRT would have to be replaced/upgraded far sooner than LRT)
You've hit the nail on the head. It's something that makes the map look pretty. That's it.
If you want to 'close the loop', paint some bus lanes on Sheppard West from Sheppard Station to Downsview Station and call it a day. You'll get from Sheppard Station to Downsview in 10 minutes.
You probably don't even need the bus lanes. The 196 Sheppard can take you between the two stations in a few minutes.
I mean middle of nowhere by little no no walk up destinations on the route, it would be almost 100% bus transfers.
hmm, so take an LRT, take a subway and take a BRT? What are we building an amusement ride?
Nope. Usage on Sheppard East was projected to be greater than 4,000 pphpd. That's above the practical limit for BRT. If you were to install BRT on Sheppard East, on day one you'd need to replace it with LRT. Keep in mind that the modelling needs to be redone now that the extension of Line 2 will be terminating at Sheppard Avenue East. This likely means that usage of SELRT will be a little less than 4,000 pphpd, but still more than enough to justify LRT.
Furthermore, on both Sheppard East and Finch West, operational costs of LRT are significantly lower than for BRT. According to the Sheppard East & Finch West EAs, once you get over about 2,000 pphpd, BRT becomes more expensive than LRT to operate. This is because BRT needs more vehicles, more drivers etc...
Last number I saw was 3,100 was for Sheppard East, and that was before the Bloor-Danforth extension. And remember, that peak hour peak point number is for just east of Don Mills. East of McCowan, that number drops off a cliff. The numbers west of McCowan do justify LRT, but they're also well within the range of BRT.
I'd say that BRT becomes impractical (and very, very expensive) once you reach 4,000, so it's probably best to built the LRT with 3,100 then have to replace the BRT in the not too distant future.
That is true, but I don't think it will reach 4,000. I don't even think it will reach 3,100 now that the subway is being extended. The total ridership will likely go up, but the peak point ridership will go down.
I just think there are better ways to spend the ~$650 million that would be the difference between the LRT and BRT option, especially since the massive MSF at Conlins is no longer being used for 2 lines.
