ehlow
Senior Member
ehlow -
I think you maybe misinterpreted me. I wasn't talking specifically about the ECLRT, or at least its subway component, but rather the Finch and Sheppard LRTs and the Eglinton East surface ROW.
The Crosstown's underground portion is, in every way, a subway. It has subway costs, subway design and subway performance.
As has been pointed out extensively here before though, the surface LRT components will have route design largely similar to the surface routes they are replacing, so as to provide "local" service, with most assuming a stop spacing of 400-500m.
As for vehicle capacity, yes, you are right. LRVs can have significantly higher capacities than even articulated buses. So what, though? The only way it makes a difference is if you start reducing frequencies to compensate (e.g. 4-5 huge LRVs/hour as opposed to 20 buses/hour). The problem then becomes you're making people wait longer, slowing down their trip!
Fair enough. Although I will point out that the surface part of Eglinton does have wider stop spacing than the current bus does.
I used google maps to count the existing bus stops that won't have LRT stops, I counted 10 stops removed from the surface portion.
Increasing vehicle capacity matters if you want to increase the capacity of the line. The buses are very full at rush hour. The frequencies of the Eglinton LRT should be quite good, my impression from going to the public meetings is that it will be about the same as the subway. It's better to have one LRV than 5 full buses bunched together on the road.
