Don't even think I've ever been inside a cab ever since downloading the Uber app. Of course, ideally I'd rather do neither, but bike whenever possible.
I have not confirmed the details, but a poster over at CPTDB "Xtrasteve" has posted what appears to be a comprehensive list of the TTC September Service changes.
If accurate, I'm a bit underwhelmed.
My favourite is the completely pointless swapping of the 85B and 85C.
Whatever cretin keeps instituting these changes must hold their ridership in high contempt.
When it comes to service adjustments the TTC tends to create new branches within existing service levels and call them new routes.
The TTC doesn't actually add new routes or better service they just shift things around to look good.
The TTC Board doesn't care about the average rider, they just want to look good for the next election.
With regards to the 85B and 85C swap, this reminds me alot of the 69 Warden South renaming a few years ago.
The 69 Warden South at one point was simply the 69 Warden South signed either via Birchmount or via Warden. It all depended on which routing it took leaving the station.
In any case, they individually labeled them 69A Warden South via Warden and 69B Warden South via Birchmount.
It made zero sense then and still doesn't. It wasn't like it confused anyone.
My point is, if somethings not broken don't fix it.
I can see how the 69 having two distinct routings could cause some confusion, even if they both ended up at the same spot sooner or later. If you wanted to go to Birchmount and Sadler, for example, it would save you a hell of a lot of time to get on the Birchmount branch, rather than doing the scenic tour via Warden. So assigning branch numbers for optimized wayfinding makes sense.
What I can't fathom is how exactly changing the 85B and 85C around helps anyone. People are used to the way things are now, forcing them to relearn it, and gain NOTHING in the process, is done solely out of malice. There is no alternative explanation.
I have now confirmed that in the September Board period there are in fact some modest improvements coming to Line 1 subway service in the peak, mid-day, and early evening periods.
But there will be no improvements to Line 2 or Line 4 service.
Ironically I used to take this bus and I appreciated that they added the letters
This is currently listed on Merxx - I am sure there are some UTers who have ideas?
Fare gates...anyone have injuries from them?
I've had them crush my hand on more than one occasion, bash my exposed shin, pretty sure had one close on my neck when I dropped something. There's more that I'm forgetting. And the speed... it's awkward and slow. Disrupts the flow exiting platforms/stations.
Mods can move this to appropriate thread (maybe it's a Presto one since I couldn't find a Fare Gate thread).
I only seem to have problems with the wide accessible ones. Early on I tried to walk through one after someone came. First it swung closed, barely missing it, and then, despite my exiting, it didn't swing the other way, and I walked into it, and it didn't yield. I ended up on the ground.
And again exiting through one just yesterday, it seemed to swing open slowly, and even though I slowed down for it, it felt like it stabbed me.
Normally I just avoid the wider accessible gates - but it's not possible at stations that don't have any regular ones.
