Also I think the bigger picture needs to be looked at...while TBM tunneling 'might' be the same or slightly cheaper than C&C in certain applications, if the cost of building a deep station + TBM is substantially more than a shallow station + C&C then the decision needs to be made.
What makes you think that this decision isn't made? All our subway lines built after the mid-1950s have been a combination of C&C and TBM. The proposed Yonge extension is also a combination of C&C and TBM. Surely the are doing exactly this, using the cheapest appropriate technique. I'm confused as to where people think there is a significant (or any) cost savings to be made.
I've mentioned this before but if the original sheppard subway of 5.5 km costed less than $1 billion, i don't understand how figures can almost double in a decade....$2.2 Billion for 8 KM? How did subway construction jump from $180 million/km to $280 million/km in one decade?
In earlier posts I've demonstrated clearly how this happens. It's simply inflation. You don't use the Consumer Price Index to calculate the inflation of a construction job; you use a construction price index.
First, the 8.6-km Spadina extension is 43% longer than the 6.0-km Sheppard line (remember the tail tracks). So at Sheppard prices starting 14 years ago, Spadina should have cost $1.43 billion instead of $1 billion.
Sheppard construction started in about 1996. Spadina construction started in about 2010. If you started Sheppard in 2010, you'd add 14 years of inflation. For estimating, a general rule of thumb for the construction price index is 4%. Add 14 years of inflation to $1.43 billion at 4% and you get $2.48 billion. Almost exactly the same as the $2.44 billion cost for Spadina.
If you actually dig out the real construction inflation rate over the last 14 years, you'll find that it is actually higher than 4%. I wrote an extensive post previously on this quoting Ministry of Transportation data. It was over 5% I believe. At that rate, Spadina should cost $2.8 billion rather than $2.44 billion.
If anything, Spadina is being built for less money than Sheppard ... or perhaps we shouldn't be surprised if Spadina comes in $400 million over-budget.
And why is construction inlflation much higher than the consumer price index? The primary factors for construction are salaries, fuel costs, steel costs, and concrete (rock) costs. While salaries may be at, or even below CPI, if you look at the fuel, steel, and rock, they have all increased in price significantly faster than inflation over the last 14 years. You might have noticed this at the gas pump! The transportation cost for rock and steel is a significant part of their price ... and part of the reason rock and steel costs have increased. Though the tougher regulatory climate for quarrying, and the increase in commodity prices (steel) are a factor as well.
