Megaton327
Senior Member
If I remember correctly, some go stations have heaters activated by a push of a button also.
Many, if not most, of them do.
I wonder if having heated shelters outside on the platforms would cause problems with homeless poel trying to sleep in them?
I must be missing something. How can heated platforms outside provide heat that will do much good or not waste money providing heat to heat outside platformsI wonder if having heated shelters outside on the platforms would cause problems with homeless poel trying to sleep in them?
Not sure what this has to do with the Eglinton Line. The drawings since day one have always shown a single glass panel with no sidewalls, let alone doors!The heated shelters are generally sealed, with doors. They do not heat the whole platform, you walk inside, the door closes behind you, and if the temperature is under a certain threshold, you can press the button inside to activate the heater for a few minutes.
Smoke alarm?The full seal that the heated GO shelters provide are prime for teenagers looking for locations to hot box however, especially the more isolated ones. I remember walking into one of the shelters at Kennedy GO and it absolutely reeking of weed a few times.
Sprinkler!Smoke alarm?
