August 8, 2013
Stage 2 – Hydro Relocation
The Eglinton Crosstown is a transit project that will provide rapid and reliable service across Eglinton Avenue including an underground central section. The Crosstown will be up to 60% faster than bus service today.
What Work is Starting?
What: Crews will need to relocate overhead power lines for the ongoing work of removing piles in conflict with The Crosstown tunnel route. The piles are located on the north side of Eglinton Avenue West near Old Park Road.
Why: Piles were previously installed in the roadway of Eglinton Avenue West as underground structural support for a rapid transit expansion program that was initiated in the mid-1990s and later cancelled. This material needs to be removed to make way for the tunnels for The Crosstown.
Where: The piles in conflict with The Crosstown tunnel route are located on the north side of Eglinton Avenue West near Old Park Road. Additional piles on the south side of the Eglinton Avenue will be removed in a further stage of work on The Crosstown.
When: Pile removal has commenced on the north side of Eglinton and will continue once overhead power lines are relocated safely out of the way. Since space in the area is limited, construction equipment will be moved in and out as it is needed for each stage of work. Relocation of the power lines will commence later. Pile removal will continue following the relocation of the power lines. The preparation and relocation of power lines is expected to take several weeks. Some works may be rescheduled or adjusted due unforeseen circumstances. Construction noise and some vibration can be expected.
- See more at:
http://www.thecrosstown.ca/news-med...-west-near-old-park-road#sthash.rDchGrQM.dpuf
