AlvinofDiaspar
Moderator
The point would be to spread the venues out though (If the IOC is going to allow venues outside of the host country, venues outside of Toronto will not be an issue), not cluster them together. Temporary venues don't need to be temporary. The buildings can be repurposed as community centres afterwards. Toronto's 2008 bid consisted of 3 different clusters within the core. It could essentially be the same, but spread out between Toronto and Hamilton instead of simply in the core.
I think building temporary facilities as permanent is going to add to the cost significantly done en masse. Sure you can have things like waterpolo, with pools and facilities that can be repurposed afterwards, but the biggies like athletics and aquatics? I don't think so. Recall the whole spread out plan under the original Pan Am 2015 bid and how it got (relatively) re-centralized because there is a certain efficiency to centralization. There is also the issue of reusing existing facilities - which is of course less of an issue in Hamilton or even Markham (with their sports plex by Unionville Station) but more of an issue in Mississauga, given the location of the whole Hershey complex.
