Jonny5
Senior Member
"We need more study".
That's what came up on the wheel of spin phrases.
The oil sands have nothing to do with electricity generation in Ontario. Our power comes from Hydro, nuclear, coal and natural gas - if you want to reduce or eliminate any of these you need to find a viable alternative. Is that windmills? How many windmills does it take to reliably replace the power of Pickering nuclear station?Stunningly stupid.This is what we need more of. If you have 45 minutes some night take a look at this great piece on the Albert Oil Sands.
There is waste heat recovery systems that could use the wasted heat generated by industry to power electricity. However, there are those who would be opposed to even that (IE. David Miller).
To make cement, for example, requires a lot of heat. The heat is now just pumped out the smokestacks instead of being used for generating electricity. Steel mills could also generate electricity if they could get approval.
Currently, oil is refined to run vehicles, heat homes etc. and is a finite resource. If we were forward thinking wind and sun could be harnessed to run electric cars, power homes etc. and could reduce/replace nuclear, coal and gas in the future plus there's no shortage of it.
Yes, and when it becomes either too scarce or expensive to utilize for those purposes we'll use or invent something else. Before we had oil our vehicles were powered by coal, wind and grains, our homes were heated by coal, wood or animal oils (including whale fat).Currently, oil is refined to run vehicles, heat homes etc. and is a finite resource.
Put the nuclear plants and the windmills on Hudson's Bay or another distant, largely uninhabited part of Ontario, pay off the natives, and you won't hear a thing.If people have a problem with windmills, wait until more nuclear plants are proposed and see what happens.
Pay off the natives? Are you serious?
Why not? They generally have ownership to much of the land, and even if they don't have ownership of the land, they will generally be the biggest complainers and obstructionists. There is a big pipeline going in across the NWT I believe, and financial compensation to the native bands in the affected areas was key to the project proceeding. Money always talks.Pay off the natives? Are you serious?
There is a shortage of sunlight every night. At its best, any given wind farm is only efficient about 20% of the time.
You will still need something like nuclear for baseload supply for some time to come.
