ssiguy2
Senior Member
Aren't there currently UTurns for cars planned to be built in to the system already, like on St Clair?
Where, specifically, would you have the above-ground section running between Bayview and Brentcliffe?
Where, specifically, would you have the above-ground section running west of Dufferin?
Have you seen those streets in person?
What do you think the average stop spacing is now in the planned for tunneled section?
What do you think the underground station length is in the current plans?
Are you aware that in the highest demand portion of the line (underground 12km) that they will be able to use ATC and cross-over tracks to turn back trains, thereby significantly increasing frequencies where they are needed most?
I mean UTurns where the train is submerged while entering an underpass so they could UTurn just before the light.
The Eglinton should average at least 1 km thru the entire route not just underground. It should be a transferless line right across the city. If it goes just to Kennedy then it's not a cross town route no more than Bloor/Danforth is. I understood the stations were 100 metres but I was stating it noting that at grade stations only need be 70 metres for now. Toronto could have a complete LRT cross town route that would actually be fast by simply making sure that where there is not an at grade station there is no cross section. It could easily done by moving the funding from Finch to Eglinton.
The Sheppard line should be stopped immediatly. It must get to STC with again fewer stops and no stopping unless for an at grad3e station.
TC can be salvaged into a rapid transit system if they would set priorities.
Miller tried to convince people that you can have local service that is also rapid on the street. By trying to satisfy everyone no one gets served well.
It's not to late to make TC a true Light Rapid Transit service as opposed to a streetcar.
