junctionist
Senior Member
On a side note, if something like that second map were to be used for the full subway map in trains, it shouldn't trade one convenient feature for another. In this case, the second map lacks the station address.
There you go again, Dentrobate, with the whole not-reading-what-you're-responding-to thing. His first sentence: "I'm lifting this from the Spacing Wire."
Would it surprise you that I have a mild case of ADHD ? I tend to zone out through reading long passages. I'll try less skimming, more full readings next time.
Thanks for posting, Darkstar! I generally really, really like the Spacing people's ideas for the TTC, but I'm not too crazy about these maps. It's mostly for the reasons already mentioned. The bus connections map looks great, but I really question its utility. How many people actually know the numbers of bus routes other than transit geeks and people who ride the route every day and don't need a map? It's okay in the Ride Guide where you can easily look where each route number goes, but on a wall mounted map it could prove more confusing than helpful.
. I find the Ride Guide useless by itself. With all those overlapping red lines, often if I'm not familiar with a route, the only way I can figure out which way the route goes - particularly when there are A, B, C, and D's, is to take a look at the route schedule on the website - which doesn't work well when you are standing at a station. I have no idea why colour isn't being used to make a better Ride Guide.The streetcar map is useless, the surface connection map already exists in a superior form in the Ride Guide.
Good to hear! It will make your own responses much more interesting and relevant. I think you're right about the station addresses. Given the choice between them and bus routes, I'd probably pick the latter if there were some better way of identifying the route numbers.
Really, you need something simple and iconic.
Indeed - I would never suggest such a thing - that is what the Ride Guide is for!And a map showing every possible route number connection with every subway stop most certainly isn't iconic and simple...
That's certainly worth doing. But the ride guide isn't posted on subway trains, streetcars, or buses.^ and ^^: Yes, a better option would be to tweak the Ride Guide to make the more dense tracts of red less...nebulous.
