measuredmove
New Member
When ever you are ready to post the specs for the lower level- I can start on the livingroom/dining room. I don't anticipate space will be as much of an issue there.
I also wanted to add that I tried to fit a dresser or chest of drawers, which typically measure about 18" depth, in the 2nd bedroom but it was a squeeze. Not sure if you have dressers or whether you'd opt to get a closet system for the bedrooms that could incorporate drawers as well as rods.
I may need to split the file into 2 at this point, as my computer is starting to grind away when rendering and will be hard pressed to create the full video when everything is modelled. But I should be able to combine the 2 floors for the final output video.
Hope that you are still enjoying the process and that it is proving to be helpful and not too costly if you have to replace furniture!
Cheers
Cheers
