GenerationW
Senior Member
Two subways ending at Rouge Hill -- now that's a fantasy map!
Person 1: DRL must have wide express stop spacing to save on travel time to give people incentive to transfer to it and use it!
Person 2: Let's give it a large meandering path that wastes travel time to connect as many dots on the map as possible!
It will be nice if another line runs from Coxwell/Queen to Roncesvalles so that the streetcars on King/Queen can be eliminate. The current mixed traffic simply doesn't work.
The Queen line was planned 100 years ago and was brought on the table serveral times yet never realized.
What is the utility of having a rapid transit line with close enough spacing to replace a streetcar? I see the ideal stop spacing being closer to 1000-1500m than the 500-800m on the Bloor-Danforth.
I would say that surface transit frequency on the King or Queen Streetcars could be reduced especially with the newer low-floor LRVs, but the lines are far too valuable to be ripped up.
And yet every day I see people who get off the Danforth subway at Broadview and take the 504 downtown to King rather than change to the Yonge subway.The streetcars are ridiculously slow and get stuck in traffic jams all the time, I hate using Toronto streetcar service and much prefer taking the bus up to the Bloor line and the subway across if at all possible, or walking.
I can't imagine that many people will want to take the streetcar if a DLR is built under King or Queen. The streetcars are ridiculously slow and get stuck in traffic jams all the time, I hate using Toronto streetcar service and much prefer taking the bus up to the Bloor line and the subway across if at all possible, or walking. Hell, driving on Gardiner/Lakeshore/DVP is usually much faster than taking the streetcars even in rush hour traffic jams. My guess is that what will happen if a DLR is built say under Queen St, is that the portion of the Queen streetcar that runs along the subway route will be removed, parallel routes like King and Dundas will remain but ridership will go down by 50%. Maybe a bus will remain like route #97, or #85 west of Don Mills, but it will be infrequent. It is just too expensive to have duplicate streetcar & subway services and no one will want to use the streetcar once the subway is built.
They have utility, but to operate most effectively as a relief line, the stop spacing on the DRL will need to be wider than what is considered the norm in Downtown Toronto. I don't like the idea of directly replacing streetcars with subways, as there is an additional cost to building additional stations to replace the streetcar service, and the additional parallel transit capacity will be needed if the cost of energy doubles or especially if the GTA is expected to grow by 3 million people by 2035.
The Queen line, if ever built, will NOT be a relief line.
In the central section (Parliament to Dufferin for example), the spacing can be limited to 500-800 meters. I am sure the vast majority will prefer take the subway over the snail speed streetcars whose schedule is completely unpredictable. Outside the core area, 1000 meter is appropriate. Most suburban riders will still prefer taking it and then walk for 5-6 minutes than be stuck in the streetcar for 20 or 30 minutes more but arriving at the doorstep.
If the subway gets built, surface transit should be removed. Not to mention the streetcar stops are 2 or 3 times more frequent than they should be. Won't kill to walk 300 meter, will it? I would even suggest prohibit cars from running on Queen and King (central part) completely, when Richmond and Adelaide are just close by. Our streets will be so much nicer!
