News   Apr 10, 2026
 877     0
News   Apr 10, 2026
 1.3K     2
News   Apr 10, 2026
 2.5K     0
Before I am able to respond to the analysis made by @reaperexpress, would it be possible to share your *.kmz file?
As for calculating more realistic travel times, you will find many assumptions and parameters in my Master Thesis (esp. Chapters 5 and 6).
I will more than gladly model travel times for your alignments, but I can unfortunately only use assumptions and data other people provide to me, as I have to minimize the risk that my assumptions are misinterpreted as me sharing any internal HFR plans...
The .kmz should be accessible from the link below, if not let me know.
https://drive.google.com/file/d/19KNDK59-QULqec_ygJk8Qqlns9dOVurL/view?usp=sharing
Since your model actually accounts for acceleration and deceleration, I've gone back and added in speed limits at a higher resolution than before (though nowhere near as detailed as those from @crs1026 above). The radius measurements which the speed limits were based on are also included in red, for reference. The speed limits are included in the description of each segment.
There are two scenarios: "OptionA" and "OptionB". "OptionA" includes major changes to the ROW, while "OptionB" largely follows the existing ROW.
Sample of .kmz:
I've never been quite clear on the title status of abandoned rail corridors, particular those that have been gone for many years like the former Havelock sub. . It is apparent that there are some encroachment in settlement areas, but do we know if the corridor is otherwise available without significant acquisition? I recall some or all of it might be an communications easement which would hinder development. It appears from Google that the corridor appears relatively unencumbered.
I realize that VIA has its eggs in the Havelock basket, but it seem too bad that they didn't look at the CP corridor from Belleville to Perth (Glen Tay), maybe they did. From Google, it appears to be a much 'smoother' alignment for better speeds and traverses no settlement areas. Admittedly, that would still entail using the lakeshore corridor to Belleville, and necessitate getting CP on board..
^ that's a good question. Have any media articles/VIA HFR documents stated who owns the Havelock to Glen Tay corridor? When CP Rail abandoned it, who did it revert to? Local municipalities? I assume it's still shown as a transportation corridor in the county/town Official Plans? I believe there are some Bell or other utilities that follow the corridor.
I hadn't realized this but apparently VIA trains are using the GO platforms/through track at Georgetown. Also the station has a "for lease" sign.
Contrary to Stephen's blog post, they're not - at least not on a regular basis.
CN dispatchers have instructions on which stations have platforms where, and which platform should have the priority for VIA services. For instance, the south platform at Georgetown is the primary, and the north platform is the one that should be used at Brampton. At Oakville, VIA trains are to use platform 1 whenever possible.
At Georgetown however, this means that a train arriving from the west must proceed through two sets of crossovers from the north side of the corridor to the south, and then back to the north side of the corridor for Brampton. And with all of the freight traffic on that line, sometimes dispatchers will forgo the normal operating procedures and use the "GO" track on the north side of the corridor to keep the VIAs out of the way.
With regards to the HFR program they're developing a business plan for. Do you guys believe that there is the political will to push it through if the business plan is a little less then superb. Given Trudeau's desire to push for additional funding towards 'green' and 'innovative' projects and now with a finance minister that likely will follow that lead. Does Via Rail and HFR fit into that idea in your opinions?
On a side note, watching Thenovabusfan and his tours of Montreal's REM program it seemed that the trains out of Montreals downtown terminal were severely restricted in terms of their speed. Is that a regular issue or a on off as per the video? If it is a regular cause of delays is there opportunities to reduce that issue or is it caught up in legal quagmire like the Toronto area of multiple ownerships (GO-CN-CP etc) which makes development slow and costly.
The simple reason why the low speeds exiting Montreal is geometry. The alignment of the trackage is such that quite a few tight curves were required to enter the station. This isn't fixable without massive expropriations and trackage realignments.
It should also be noted that the speed limits in both directions less than 3 miles away from Gare Centrale - as the crow flies, mind, the on-track distance is greater - is 90mph or greater.
From watching VIA Maps lately, it does appear that the REM and other construction has imposed some temporary slow orders that are even more restrictive than the curvature. Possibly some speed restrictions could eventually be bumped up a little, eg turnout speeds might be nudged upwards as is being done at Toronto Union. But as @smallspy notes, at the end of the day, the tight curves are not fixable. The curve just east of Saint-Henri (Courcelle St) will force incoming trains to grind to a crawl, and then it's hit and miss to the depot.
Despite having track rated for 90+, many inbound trains seem to reach no more than 80 km/hr after their Dorval station stop. There is a lot of industrial and freight activity in that zone. Being routed through crossovers even once in that segment will prevent much fast running. A challenge for VIA, HFR or otherwise, is how to schedule opposing trains so that there is only one track occupied by passenger between Dorval and Saint-Henri at any one time. Try to use both tracks, and there may well be a freight train in the way, or additional crossover moves that steal speed.
We are all hoping. Best we can do. If this falls through, we'll just have to give up hope of this country ever building decent inter-city rail infrastructure.
Outside of the Corridor, Via is irrelevant. If outside the Corridor, nothing is improved, then we will never have a decent system.
A train that should take 3.5 days should not be late by a 1/2 day!
A train should run at least once a day, every day, at the same time. Otherwise, it is useless for most people.
Regarding this post:
In case anyone feels motivated to respond to this post, I would strongly suggest to open a separate thread about restoring daily passenger service in Western Canada, as this ever-circling discussion with the same poster has already monopolized the “Via Rail” thread on SSP (where he posts as “swimmer_spe”) over more than 1700 posts and has virtually drowned any attempts to discuss other aspects of the topic to which that thread is supposedly dedicated (he created that thread, apparently without any intent of allowing discussions there to deviate away from his one single sub-topic of interest)...
At the risk of beating the same old drum.....
Subsequent to our discussion about Sharbot Lake and HFR, an unnamed source sent me a very old document that gave very exact detail about the curves on the Havelock Sub east of Havelock. (I would stress that this source is not related to either VIA or CP, and there was no breach of any organization's confidentiality in giving it to me. The document is roughly 100 years old, but happily the track hasn't moved since the data was recorded, so it's still valid today.)
Anyways, based on this "actual" data, I was able to do some amateur calculation of likely track speeds, predicting a) how fast a train could go on the curves as they existed before the track was torn up and b) how fast a train might go on a rebuilt line.
First, here's the summary of what I found in the document :
Translation: There are 86 segments where the as-exists curvature exceeds 1.5 degrees. At that curvature, a "typical" train would have to reduce speed to negotiate the curve. My assumed "typical" train is the equivalent of an LRC with tilting deactivated - ie, assumed track superelevation (banking) of 3 inches, and equipment with a "cant deficiency" rating of 3 inches. (I pulled the LRC specs from memory, and may not be accurate, but it's just a straw man anyways) The speeds shown under the "FRA 3 inch" collumn are the speed allowed by the US Federal Railroad Administration for that track profile. (Note that the length of the curve does not affect the restriction - although a longer curve will require holding that train to the restricted speed for a greater distance).
So, under this baseline, in the 94 miles from Havelock to Glen Tay, a "typical" train would have to navigate 3.8 miles at 47 mph, 10.6 miles at 53 mph, and 12.9 miles at 65 mph.
Of the remaining track, trains could run 42.9 miles at 95 mph+. Because of all the slow segments, there are about 23.7 miles of track that is straight, but is adjacent to the slow bits, so trains would have to be accelerating/decelerating through these segments. These segments while straight consequently must be considered "restricted" by all the slowing down and speeding up.
The question is, what can VIA do to improve on this? One solution would be to increase the banking of the curves and/or use a tilting train that can handle curves faster. The collumn "FRA 6 inch" shows the speed restrictions that would translate to "LRC train with banking operating as designed" - ie 3 inch superelevation, 6 inch cant deficiency. As you can see, if VIA either found a tilting train, and/or banked the curves more, speeds through all those tight curves would rise.
The other alternative for VIA is to physically straighten some of the curves. It would take some pretty hefty engineering expertise to model that, but one can see that with the sheer number of restrictions, correcting a small number of curves would not produce any meaningful straightaways, and the time gained by fixing any one restriction is a matter of seconds. One would have to build a fairly long stretch of new track to gain a better end to end timing.
So, what does this mean for end to end time? I took @reaperexpress's chart, and did some of my own calculations. As a baseline, I assumed that VIA would not upgrade the existing line east of Smiths Falls, so current timetable timings would remain unchanged. I assumed that the section following the CP Belleville Sub through Perth would be good track, but with a speed restriction through town (old timetables tell me that CP imposed a 50 mph restriction on passenger trains through Perth). I did a Google Map arbitrary assessment of curves and speeds west of Havelock, using data from another old CP timetable which restricted RDC equipment to 60 mph on certain curves - meaning these were all likely in the 2 degree range.
The bottom line? By my data, the "uncorrected" best time I could model, excluding time lost in meets, station stops, and contingency, was 3 hours 55 minutes. That doesn't sound all that appealing. However - using my "LRC with Tilting" scenario for only the Havelock-Perth segment, the time improved significantly to 3 hours 35 minutes. I have shown my data against @reaperexpress 's estimate, and also against the best timetable time I could find from CP days. (The latter probably assumed 75 mph top speed, where I assumed HFR would achieve 95-110 mph speeds on tangent, but I was fairly conservative around the accel/decel issues). If one assumes, as @reaperexpress did, that more speed can be squeezed out of the segments east of Perth and west of Havelock, things look much better.
There are so many assumptions and unknowns that one could poke huge holes in this data, and I'm not claiming any expert knowledge. But with some declaring that "tilting is the magic solution" and others arguing for straightened tracks, I though this at least put some perspective and bounds around what reality might be.....please, Ottawa, tell us the straight facts.
Food for discussion, and by all means rip it to shreds.
