innsertnamehere
I always saw the east and west DRL being one line, but with different stop spacing on the two sides of yonge. around 1km spacing on the east side, with 6-700m spacing on the other.
No it doesn't. There are stops at locations where there are no bus intersections, such as Sasamat and Arbutus.Vancouver's BLine has stops only at bus intersections.
Nice try though ...
Also, the B-Line always runs along a route where there's still frequent local service. That isn't the intention for the Transit City lines we are currently building.
Though this is unrelated to the thread, I thought I'd post a DRL idea anyway. Gweed's map piqued my interest, and today's accident got me thinking about the ability to move trains to different lines. Also, I've always been interested in Chicago's downtown "Loop".
So basically the DRL East and West would be interlined with Y/US. Both would have uni-directional, counter-clockwise sections that would use the current tracks on the Y/US. Yonge south of Bloor would have a clockwise loop.
Westbound trains on DRL East would travel north on Yonge, then north on University-Spadina. Concurrently, southbound trains on University-Spadina would travel south below Bloor, head east along Queen, and meet-up with the DRL East proper. The DRL West would use the southern section of Y/US. Eastbound trains travel north on Yonge, west on Queen, and south on University-Spadina; meeting up with DRL West proper.
The total new tracks would be somewhere above 15km. Y/US would remain intact, except with the additions of a connection along Queen, and a portion of Yonge's loop from Lower Bay to Yonge northbound.
The 16 run parallel to the B-Line from Arbutus to Granville. I suppose if you use that criteria, any stop on West Broadway or West 10th is a transfer point, as the B-Line always parallels local buses....Arbutus bus intersects with the BLine.
It's true that the two need different stop spacings, but I would argue that the two areas that they need to serve on either side of Yonge don't really coincide well in terms of alignments. I think the DRL on the east side needs to serve the area between Queen and the rail corridor, while the DRL on the west side needs to serve the area south of rail corridor.
When you try and map this out in terms of alignments using a single thru-line, it becomes pretty convoluted. What you end up with is a massive swing south just west of University, cutting through some pretty dense development. That's why with the two branches being extensions of existing lines, you get a lot more freedom in terms of where they go from downtown, including more options for following existing roadways.
This is a great explanation...but does it mean that the addition of a second platform at Union was a waste of money?
To further what I described above, I'll post a couple quick graphics that I did earlier that illustrate the downtown section, and more specifically the Union section, because from the system map it can be a bit confusing.
There are a couple minor inconsistencies between these maps and the system map I posted earlier, specifically relating to the alignment of the DRL East after it exits the CBD, but it's relatively minor.
I am not sure if you are going under the ACC, under the Gardiner, or weaving between the foundations of the Gardiner - I do not think there is enough room between the ACC and the Gardiner. The Gardiners foundations are prestressed concrete piles that go down about 6.5m below grade. A tunnel would have to go well below the bottom of these foundations, which may not be realistic.
