News   Jul 29, 2024
 106     0
News   Jul 26, 2024
 1.4K     1
News   Jul 26, 2024
 1K     0
Transit City Plan
  • Transit City
    Votes: 95 79.2%
  • Ford City
    Votes: 25 20.8%
    120
Aren't they supposed to build buildings along the Richview corridor?
Given that the velocity estimates for that piece of the LRT are about 28 km/hr, with only a few minutes saving using grade separation, wasting all that land seems shameful.
I'm not sure how accurate that estimate is. For Sheppard East they expect only 23 km/hr, despite a similar stop spacing and street layout.
There is still plenty of locations within Toronto borders to add highrises - this is not Tokyo; but only a few continuous corridors suitable for transit.
The stop spacing for Eglinton in Etobicoke is much wider than for Eglinton or Sheppard in Scarborough, hence the higher speed. All those major north-south roads in Scarborough create much tighter stops than you get in Etobicoke. The stop spacings are shown in the EA report, which for Eglinton gave about 23 km/hr for the leg through Scarborough, but 28 km/hr for the leg through Etobicoke.
The funding allocated for RT upgrade and extension is almost certainly sufficient to extend BD subway to STC.
If they decide for subway though, they should consider a new alignment under McCowan or under Brimley. So far, both leading mayoral candidates support the most obvious, but not necessarily the most effective, option of reusing the existing SRT corridor.
Martin Grove to Jane: 5.4 km. Major cross-streets (for Eglinton): Widdicombe Hill, Kipling, Wincott, Islington, Russell, Royal York, Scarlett. Average distance between major traffic lights: 0.68 km.
Vic Park to Morningside: 10.4 km. Major cross-streets (for Sheppard): Commons Dr., Pharmacy, Bridlewood, Palmdale, Warden, Aragon, Ametyst, Birchmount, Allanford, Kennedy, Redmount, Agincourt, Midland, Glen Watford, Fulham, Brimley, Brownspring, McCowan, Havenview, Massie, Scunthorpe, Markham Rd, Progress, Gateforth, Lapsley, Neilson, Murison, Breckon. Average distance between major traffic lights: 0.36 km.
OK, then the difference, 28 kph vs 23 kph, is believable.
Aww man here we go again.
If they run underground in a tunnel at the same speed (and more frequently) than a Toronto-style subway, then yes, they are rapid transit.
To suggest otherwise is astounding.
If you are already digging, then there is no reason why not make that a metro instead of a tram. The difference in cost is minimal. The metro is superior, and the better long term investment.
I've never referred to anything in Chicago as a subway.
You could. They were underground lines for cable cars... that is a subway. They still have the tunnels to this day, but I think they're closed. But yeah, that is a subway, be it by bike, cable car, tram, or highspeed rail.
1) Eglinton will be more useful to more people right now than Sheppard would be in 50 years. Ridership on bus only Eglinton exceeds ridership on the sheppard subway. The money is better spent on a long Eglinton line.
Not necessarily. First of all, a full sheppard line will actually be useful. Connectivity of the system matters a lot, much more than you can imagine. Especially for cross town travel, which we are very ill equipped for. The sheppard line is much cheaper in cost, so why not finish it? The thing is that construction of it has already begun. What has been made thus far is a success. So, naturally the next step is to finish building the rest of it.
If there was no sheppard mini-line, then I would say lets build eglinton and forget sheppard in the near future. But sheppard is already there. Limiting it is a problem.
Most importantly, land use is what makes or breaks stuff. With adequate landuse, sheppard can be well off on its way to a great story. Unfortunately, what build toronto, integrating land use and transit planning, is something of the past. It's what paranoid conservative and liberal dickheads call socialist authoritarianism - but because of this socialist authoritarianism Toronto was the best city in north america, and today is among the best.
2) Trams can be rapid transit, if they're implemented correctly (as in Calgary)
That requires much grade separation. You can not do that on Eglinton in a way that can be good. It will require digging - costs that bring it to 97% of subway construction costs. Toronto's trams stop. They accelerate, slow down, they stop. At stations, at lights, because of heavy snowfall, you name it. They are not in any way rapid transit.
However... I would not mind having a tram line on Jane street. That is where the western terminus of the sheppard subway should be one day in the future.
3) Again, that's doubtful. An Eglinton line will be more beneficial on its own, and if interfaced with a downtown relief line its benefits are increased dramatically.
Think about it. A high capacity system running from Jane to STC on sheppard vs a low capacity tram going above ground from the eastern end of the green line... going above ground stopping and whatnot on a regular frequent basis. Then going underground into what should be a metro, not a tram for 13 km. Then popping back up and chugging along with nice coffee breaks at all those red lights. Like no thanks. If you are going to dig for 13 km then just spend the two percent more and make it a subway. It helps future generations. And if we take land use planning into consideration, the benefits will be threefold.
There's nothing stopping them converting it to subway in the future if necessary (but it would be a long, long, way off, given that even the passenger demand for the 2030s is well below that the LRT can handle.
The models used for that study are bullshit.
On the other hand, sheppard models did justify a subway to STC. But why bother looking at real things when we can concoct some medicine for the masses to swallow?
For not much more money, one could simply do it as subway from Jane to Don Mills; but then you would have to change vehicles (twice if your travelling from Victoria Park to Royal York) and the trains from Jane to Don Mills would come less frequently. I don't know how anyone would benefit from this.
A very reasonable thing in my opinion, to be changing modes. It's a long route, what do you expect?
Or you can just build it all as a metro from the very start. Stockholm built subway lines before any demand was there. The benefits were priceless. You see, the ridership comes there, when one integrates land use. Toronto has been known for this. It's what made our current system as great as it is.
And besides ... two subways to Scarborough Centre?
Why not? I personally would keep the RT going there for some time, and get sheppard to go down to there first.
Compare ridership of Sheppard subway plus/I] the Sheppard E bus as that is a more comparable analogy to Eglinton E than simply looking at the Sheppard subway. Riders still taking buses south to the Danforth line from the Sheppard area would be attracted to a one seat ride to Yonge
The problem with this methodology is that it would suggest that the sheppard subway is not too bad.
The paranoid camp wants to destroy it by making it into a tram. Insane, ain't it?
Why would the TTC want to make the same mistake of the Sheppard Stubway on Eglinton? There is no bias. The demand on Eglinton beyond 2030 can be easily handled by LRT|. Why would you spend the extra money on a subway if a cheaper mode can handle the projected ridership?
Integrate land use and you will exceed tram levels quickly.
Why spend extra money for the metro - because the cost difference is minimal.
As for your biased studies that use today's figures and underproject into the future... throw them in the trash bin.
Just add some high rise towers around some stations. You know, like when they built the green line there were quite a few high rise complexes a short walk away from the metro. New employment spaces were mainly around the lines. It makes perfect sense.
The original Eglinton West heavy rail subway was only between Allen Road (Spadina subway) and Black Creek Drive. It was not to go to Jane Street. The current plans for Eglinton is to extend the underground subway portion east of Allen Road to the Leslie Street/Don Mills area, the section not including in the original design, with the remainder sections east and west being above ground right-of-way.
What are you trying to say my good man? What? Let me help you.
The original eglinton plans were to make it an entire crossroute. Eglinton west metro was only the tip of the iceberg for what was to come. Eglinton west on its own was small. It should have been bigger. But, it was just the first piece to the puzzle. Nobody is insane to build such a small metro line and stop with no plans later.
No; in current dollars they allocated $1.4 billion. The extension would require about 6 km and that only gives you about $230 million per kilometre. In current dollars the cost is closer to $1.7 billion. If they had that much money to burn, they wouldn't have deferred the piece of the RT extension to Malvern to save only $386 million.
The other problem is that most of the $1.4 billion is for the extension to Sheppard, not replacement of the existing service. If you build non-grade separated LRT to Sheppard, your still looking at nearly $300-million, raising the cost to $2.0 billion.
It doesn't seem likely that the province is going to cough up extra money to fund a project that can be accomplished with a lot less money.
Tell me about it, the spelling discussion was more constructive!
What on do you mean. An LRT in a subway tunnel with ATC and 90-metre trains IS a metro!
The cost difference is minimal, but with one you've got a stubway, and the other you can keep the vehicles going to Pearson and Kennedy. LRT is more than sufficient for these outer sections for decades. The tunnel can be converted to subway in the far future if necessary; the subway tunnels are a bit smaller than the LRT tunnels (which is the problem with converting the Sheppard subway to LRT).
The models used for that study are bullshit. On the other hand, sheppard models did justify a subway to STC.
The Eglinton models give numbers similar to the "sheppard models" that you say justify subway; remember that when the modelled sheppard to STC they also modelled Eglinton. And it's not even close; the model would have to be hugely off to justify subway. There is no factual basis for your statement; you are simply pulling it out of your imagination.
Much of the traffic at Don Mills/Eglinton has boarded at Yonge/Eglinton. This is a long route, but the same length on Sheppard is a stubway, that must be extended? Give me a break!
No it wasn't. Look at the 1960s drawings. The centre section was subway, and the proposed extensions were RT, the same as they showed for the extension from Kennedy to STC and from Kipling to Pearson.
It seems that their current-dollar projection (for SLRT reaching Sheppard / Progress) surpassed $1.4 billion. The latest escalated-dollar projection is more than $2.5 billion. If we assume average escalation period 8 years and construction-cost inflation 6% per year, the current-dollar cost would be about $1.56 billion.
That depends on the routing though. An LRT connection up McCowan (less than 2 km between STC and Sheppard) should not cost more that $150 million, and would be arguably better for people from places west of McCowan who want to get on subway.
In essence, the mode change at Kennedy forces an overly expensive fully grade-separate LRT east and north of STC. The fully grade-separate LRT there is not justified by demand, but they have to build it to avoid another mode change at STC. If the mode change at Kennedy is eliminated, then the mode change at STC becomes acceptable, and allows cheaper LRT options from there.
They extended the Yonge line to a nondescript suburban wasteland like Finch in the early 70's (and turned back some trains at Eglinton for a number of years) but I don't hear anyone saying that was a mistake. Yet extending Sheppard to the STC would somehow take 50 or more years to be useful? Get real!
Crazy thought: Seeing as Transit City lines are more focused at local service, could we not have a Sheppard subway underground for intermediate and long distance commutes, with the tramway above ground for local connections?
Eglinton would be harder to execute, since the center corridor will already be underground. Maybe if/when capacity is met, convert it to heavy rail powered by overhead wires so that it can still operate in the road median at the ends.
The fundamental flaw from word go with TC is that in it's endevour to provide better service to everyone it serves no one well.
The City refused to prioritize what lines needed to be built and what kind of service they should provide.
TC is a suburban service with little benefit to the citizens of the original city of Toronto save the small Eglinton underground section. The City did not make a solid commitment to what kind of service it was to provide. They are trying to create a rapid transit network while also serving local transit needs..............that is not possible. They are two different things and hence you have low speed/capacity TC coming in with high prices. No where on this entire planet is there a suburban rapid transit system stopping every 300 meters and even in downtown areas that would still be very rare.
Like all infastructure projects TC has a certain amount of funds but it failed to face the voters andl clearly state they we can do X now and if that particular project doesn't serve your area than you are going to have to wait. TC is political vote grabbing 101. TC is a built on a "everyone will get something" mentality and that is not how infasructure is built and is no
different from other big projects. Would it have been better to have built 10 small stadiums all over the city over one large Skydome? Of course not and it is the same with transportation.
When it comes to TC there are too many lines being built with too little money. There are two priorities and until they are completed all other TC projects should be suspended indefinately.................Eglinton & Sheppard. Even STC will have to wait it's turn so in the meantime they can simply buy older MK1s from Vancouver, renovate them to increase service levels and line capacity and that's it.
Eglinton should be one line long from Pearson to UT Scar. After Kennedy it can be elevated from to Kingston and at grade for 6km using the existing GO Rail ROW. This would make Eglinton a TRUE cross town route. I've never understood why all these "fantasy maps" never include service for the hundreds of thousands east of Kennedy especially when it would be a relatively low cost project.
Sheppard?........ Downsview to STC.
These should be built as rapid transit so stations should not be closer than one km a apart with some exceptions where needed. Imagine how much larger and more coherent Toronto's subway system could be by tunneling that $3.5 billion saved from cancelling Finch/Sheppard/Malvern/LRT and putting those funds into just Eglinton and Sheppard subways.
For Toronto to get moving again and have the transit system it will need for a Metro of 10 million in 30 years the City and TTC must be honest with Torontonians and state clear priorities and let them know that tunneling is only done where required and that elevated and/or at grade rapid transit will be the rule not the exception. Unless those ideals are followed Toronto will continue to be a transit laggard.
Until the City gets a council and mayor with the honesty and balls {which negates both Ford and Smitherman} to tell the people that almost all of any new system will be at grade and or elevated. and that if you didn't want subway/RT trains going by your house you shouldn't have bought it in the first place, Toronto will continue with it's breakneck speed of subway/RT expansion that has achieved over the last 30 years.
It also means having the balls to turn to the TTC unions and tell them that all lines will be automated and have no one sitting there to make sure the doors close. All new lines should follow the Vancouver model and be completely driver less which not only improves frequency but also greatly lowers operating costs. It also means putting any new transit project out to a TRUE tender which means let the best tender win regardless if they are unionized or not. Ford would have no trouble here but this is why I also stated that councilors must also be dedicated and in Toronto they aren't.
To truly improve the TTC and bring it back to it's once great stature the City must prioritize lines, get good value for money spent, build for today and the needs of 50 years from now, create a true and fair bidding system, and have the fortitude to tell Torontonians the truth of what they can and cannot deliver.
The sad part is neither Smitherman nor Ford are up to the task.
It's been discussed over and over again on these boards. The current ridership numbers on Sheppard E (as a stubway) exceeds the ridership of, "successful", subway lines around the world. Calling it a mistake means that all those lines are mistakes as well...
Why assume such a low number? It's been running closer to 10% most years recently. It's a good question though. What is Metrolinx's assumed inflation rate?
Good point, I was assuming Progress, near the current route. McCowan would certainly be cheaper, but would fail to serve those along Progress; which also raises the problem of eliminating service along the current RT route - particularly to the relatively well used Lawrence East/Kennedy area.
I'm not sure why a mode change at STC is any more acceptable than at Kennedy. And if the LRT become surface, then travel times from the Sheppard/Markham Rd area will be significantly longer with the subway extension to STC than they are with the current plan.
I don' think it''s a crazy thought ... I've been saying similar for years. Nothing in the LRT plan precludes a future subway extension to STC if and when demand supports it. And that subway could then have relatively few stops, perhaps only at Consumers (which is presumably where the LRT would then terminate), Victoria Park, Agincourt, and STC.
Bullocks. Metro implies heavy rail and high capacity.
Why do you want to cut your capacity? If you are building so much it's best to have some in reserve. Don't forget, the models used to promote the low long term ridership figures are just wrong. It underestimates growth, and extremely underestimates what can be done if land use is integrated with transit planning, like back in the 1950s, 60s and 70s...
Howabout 1980s or 1990s?
So you're saying that we should put ourselves in the 1960s mindset. Nice way to plan Toronto, 50 years behind... primitive. In fact this thing 50 years ago was better!
The stations are a minor factor, tbh.
Don't forget that they always over-estimate the travel speeds when promoting their agenda. That way the bitter pill does not seem as bitter. You know, like putting shit in a nice package. But when it's all done and open, we say OH SHIT.
Also, did you notice how the proponents of the eglinton fiasco never focus on eglinton east? Never. That is the same thing as sheppard, no?
The reduced speeds are not necessarily because of station spacing. No. It's because of the lack of grade separation. We can't build a calgary style lrt here. Here it will be just another tram.
But that is the point, to change our thinking to believe that subway construction is bad. You see, it discourages car use, so the automobile/highway lobby here on UT likes to promote poorer options that result in more people staying in their cars.
Only those that hate mass transit can promote Transit City. Seriously. The cutting of its funds was the best thing that I heard in a long time. Lets hope that it all fall through, so that one can build something better!
Many of those lines, such as the Pink line in Chicago, did not require a billion dollars for only a few km's. They used previously available surface corridors and existing tracks, they are hardly comparable to the Sheppard line.
