News   Aug 27, 2024
 154     0
News   Aug 27, 2024
 351     0
News   Aug 27, 2024
 662     0
Transit City Plan
  • Transit City
    Votes: 95 79.2%
  • Ford City
    Votes: 25 20.8%
    120
What the heck? Don Mills is one of the widest streets in the entire city... there's huge grass areas on either side of this 6-laned colossus. That's more than you can say for Sheppard. Not only that, but neither Don Mills nor Sheppard need street parking unless they are also planning to demolish every building running alongside these roads and replace it with Bloor St.
With the Don Mills LRT. What you're claiming is not true for anything south of Overlea.
No way to fit bike lanes onto the DVP overpass and the hill directly south of it. In fact, that entire stretch may need to be widened in order to accommodate the LRTs.
O’Connor is too narrow for bike lanes as well and Pape is even narrower than O’Connor.
In a hundred years, maybe yes, or less, it could look like Bloor. Click on this link to check out this article from the Globe and Mail on controversial economist Jeff Rubin's new book Why Your World Is About to Get a Whole Lot Smaller.
Maybe I'm the only one here who fails to see how a CIBC economist who specializes in commodity futures and predicting an Edwardian streetscape for a suburban arterial have a plausible connection.
There's no intention to use Don Mills road for LRT south of overlea. It will most likely turn west on Overlea and then have its own bridge.
Of course, if the DRL comes into the picture, Don Mills LRT needn't even go south of Eglinton.
Seattle's 13.9 m (22.4 km) Link Light Rail opens July 19th. Part of the route is underground, part above ground. From a link to Seattle Transit Blog, here's some photographs of their new LRT for comparison. They use low-floor light rail vehicles. Some of their underground stations are shared with buses.
The top four stations are underground.
Wow ... and most of the underground stuff through downtown was built in the 1980s... all they had to do was change the tracks, etc. The original 2.0 km section of tunnel cost almost half-a-billion dollars back then. Makes Toronto construction look cheap!
I'm under the impression that the existing Seattle tunnel wasn't large enough and they had to raise the ceiling height (in other words the same dumb planning failure as with the SRT).
What a splendid example of why the LRT instead of subways movement is so stupid and uninformed.
The only real debate is surface vs. underground. A surface subway line would cost 90% less than a tunnelled LRT, streetcar, or even bus rapid transit line.
It is for that reason that I believe that all underground transit lines, regardless of their current mode, should be built to subway standards. The incremental cost increase is next to zero if you've already committed to building underground, but this would allow seamless conversion to subway in the future, if and when required.
That doesn't sound right to me ... the bus tunnel seemed to have quite high ceilings; and I took it both before and after it was closed for conversion (they still run buses in it as well); and I didn't notice any alterations to the tunnel ceiling. Are you sure? I thought it was primarily the track that was changed in the new sections.
Actually, I was not sure at all, which is why I said I was under the impression. Since posting that I've overcome my laziness and taken the twelve seconds required to look it up. It appears they didn't raise the ceiling, in fact they lowered the floor by about 6 inches.
