TheTigerMaster
Remind me why we're penny pinching with the Ontario Line again? We must be flush with cash if we can build this and other under-utilized subway stations on the YNSE and EWLRT.
I thought the TTC gave up on the 90 second headway target, because their combination of rolling stock and track geometry cannot operate at those headways.TTC hasn't attempted 90 second headways yet, and probably wont until the Yonge Extension is complete.
Every station would have to be built as a terminal station, and that can add significantly to the overall cost of the extensions. Crossover tracks, train storage and other facilities would now have to be built at each station along the extension. This might also necessitate purchasing additional TBMs, along with the cost of installing and removing the TBMs at each station.That's why I would prefer a continuous build model that opens a Cummer station first, then Steeles, then, maybe Clark and so on.
There is no consistent logic is how spending is prioritized.
One could argue for/against certain levels of expenditures on different projects......in isolation..........perhaps, defend those (sometimes no so much)......
But....it is not unreasonable, in theory, to expect whatever principles are applied to be applied consistently.
That certainly is not the case.
I really don't get it. The $250 million dollars being wasted on this station is likely more than enough to fix the deficiencies in the Ontario Line plan, thereby ensuring that we'll avoid spending billions in the future to mitigate these deficiencies. There is absolutely no rhyme or reason in how MX is making their spending decisions.
You mean the extension that had 2 stations cut, and where the alignment was changed to run under peoples homes just to use an above ground alignment to save on station construction costs? EWLRT is an absolutely fair target to point your finger at for being overspent, but the YNSE is by all definitions a gimped version of the original plan put forward by the Liberals. In fact, the only reason 1 of the neighbourhood stations is being built is because they're saving money by running a section above ground. If the government chooses option 1 or 2, none of the neighbourhood stations will get built. I guess the point I'm trying to make here is that YNSE should absolutely not be a project to point out for "wasting money", if anything its getting gimped more than the transition between DRL and OL.Remind me why we're penny pinching with the Ontario Line again? We must be flush with cash if we can build this and other under-utilized subway stations on the YNSE and EWLRT.
Wouldn't that have to wait until Crosstown construction is finished?2) The ATC extension to Eglinton should open by the end of the year I believe.
It's completely separate from the Eglinton crosstown line.Wouldn't that have to wait until Crosstown construction is finished?
That is the sales pitch. The reality is that the tunnel is no shorter than before and the original plan spaced out stations over the length of the line maximizing its benefit. The original plan was to have a station built into the bottom of a developments right in the middle of a new Richmond Hill Centre. The subway and bus terminal would have been connected to all the properties being developed. The subway line, GO transit, and bus routes from all over York region would bring people to this central core. The initial business case showed that an extra 15,000 riders would have taken the originally planned alignment and that was with both options having a Cummer, Clarke, and Royal Orchard Station included. Metrolinx's own evaluation in the Initial Business Case shows that the option they are going with has less benefit than the original plan (before removal of stations from any of the three options).In fact, the only reason 1 of the neighbourhood stations is being built is because they're saving money by running a section above ground.
Politics and elections.There is absolutely no rhyme or reason in how MX is making their spending decisions.
