Cross posted from the Relief Line South string:
https://urbantoronto.ca/forum/threads/ttc-relief-line-south-in-design.6155/page-766#post-1435403
jje1000 said:
I have a feeling they still want to return it (UPX) to being a more 'premium class' express at some point later on, or at least something that remains separate from RER, rather than it remaining the RER-lite service it is at the moment.
There's a number of scenarios, that's one and it made more sense up until now. I think that may have been the thinking when Wynne put a starting pistol to their heads for the CanAm Games and made them jump the plank. It was a disaster in terms of ridership however. We know and accept that being the case, but when the division CEO really was shot a few years back, why did they never fold the
entire division into GO? It's beyond conspicuous, and the remaining parallel but distinct fare systems defies rational belief. There had to be some kind of rationale at work.
This new stance from Metrolinx heralds a real change of approach, and let me take your point one step further: By allowing for a return to 'premium service'...it even furthers the case for privatizing
if! passenger numbers can be maintained. But there's catch 23 (22 with inflation added): Remove that fare equity with GO, and the ridership plummets again.
An answer for that is for UPX to return to being 'an airport premium service'...and private (allowing it to be outside the Metrolinx Act) but the physical operation folded into a greater UPX, one which has added three or four car high-platform trains to run to Bramalea to
capture that "overwhelming demand" as some have called it, and Verster refers to, as the first leg of an RER Bramalea/Union or beyond. It won't be the RER touted by Metrolinx in the past, but it could be up and running in a couple of years. There's ample headway between the 15 mins that UPX now run on their present pathings to the airport. With the added 'Bramalea service' even a 7.5 min headway between airport trains is large by today's signalling standards. That airport service can remain (perhaps with only two car trains since demand will be lessened, and thus stock will last longer and be more flexible) and continue to run into the dedicated UPX station at Union, the added 'RER light' would run into a platform at Union proper, albeit with a high platform, and use DEMU/EMU stock that can run on both, thus enabling the more 'true' RER EMUs to run the service later. High level platform(s) would also be added to the most southerly platform at Bramalea and any stops between there and Weston.
The only service that would be privatized is the Airport service, and that would justify leaving the 'UPX only' stalks in situ for that service.
Edit to Add: As per GO's historical overpricing of local fares, here's an excellent piece by
@ShonTron :
Not so fair-by-distance: GO Transit’s problematic fare system
