For those who may want to watch the West Toronto Diamond move this weekend, this is the schedule at the time and subject to change. Will have a better time frame on Friday afternoon. Everything is subject on CP, the weather and unknown.
All GO and VIA train will be using the Newmarket/Barrie Line this weekend with longer travel time.
The Contractor will be on site at 2 am Sept 1 and start work at 3 am for the removal of one of the 2 CP Mainline. It is expected that CP will hand off the whole area at 5 am to allow the removal of the 2nd track.
Earth will be removed up to 2m under the 900mm thick bridge to allow enough room to weld the bridge to the retaining wall. Rest of the earth will be remove later.
About 10 am, the bridge will start to be move into position and take a few hours for the slide.
The only location you can shoot from is along the west side of the corridor is at Old Weston Rd. Not sure if you will be able to shoot from the Toronto Water Pump Station land. Will find out Friday afternoon.
This will be the first RR bridge in Canada to have this type of bridge. The bridge is 900mm thick x 11m wide and 36m long of precast concrete section and post tension before the move.
