Toronto Southcore Financial Centre & Delta Toronto | 159.71m | 45s | GWL | KPMB
Darkside, answer yes but codes and the authorities who enforce codes are not keen when it comes to innovative procedures.
P.S. if you are talking about cementitious materials, rather than reinforced concrete (concrete with steel reinforcing), the Roman's built concrete structures that are still around today. Example: the Pantheon in Rome.
Thanks again for the reply and for your insight on the process Skyjacked. Very interesting and informative as always!
I imagine the weather will have an effect on the curing process also. Can lamps or heaters, chemicals, or even the weatherwall, be used to help slow (or speed up) the curing process?
Oh DSD you’re going to get me in trouble. I’ve derailed this thread into concrete technology. When you include so many things in one sentence, it turns into paragraphs again. I’ll try to be brief, but...
No Lamps, except for light to work by.
Heaters, every winter some Canadian rental companies pay all the bills with portable gas heaters.
Chemicals are used all the time as a plasticizer and since concrete is a chemical process to begin with I imagine there are all kinds of secret recipes for different applications. Factors like the temperature of the mix water and the ambient temperature of the day are measured for every load delivered.
Weather wall or wind protection is employed year round. The wind evaporates the surface moisture of a fresh slab and complicates finishing. Cold wind can flash freeze the surface causing all kinds of grief.
The curing process is generally measured in 1 day strength, 3 day strength, 7 day strength and 28 day strength. Of course these values can be graduated to hours or years but 1 to 28 day measurements are common to the industry. These measurements determine things like when you can strip the forms, how much re-shoring you will need and how much load you can put on a fresh slab.
At least I get to post more pictures from last week.
In the second photo you can see preparations for winter concrete work. All of the wall forms have been insulated. As the chemical reaction between water and cement generates its own heat (heat of hydration), insulating the wall forms is often all that is needed. You can also see the tarps neatly gathered around the bottom of the slab forms. They will heat the slab from underneath, probably with between four and eight 400,000 btu gas heaters.
I posted a picture on another thread that gives a different look at winterizing.
Awesome information as always Skyjacked --- Thanks for the quick education on how the process works, I feel more knowledgeable by the day!
Great photos as always!
I'm a long time follower of UT and wanted to share this view of Southcore from my condo which includes Bremner Tower, Delta Hotel, Ripley's Aquarium, Ice Towers and Inifinity.
Btw, can somebody here teach me how to make my picture bigger? Thanks.
farm9.staticflickr.com/8503/8344779558_c47a1d9811_m.jpg = change m to b
Decking over the rail corridor seems more and more inevitable as the area south of the tracks fills in.
and place only parks, public space, bike trails, and roads connecting to waterfront on top of this decking..one can only dream.
I'm never one to mind a well executed, simple, minimal Toronto Box, but I'm anticipating this Delta tower somewhat more than I am the box to come beside it.
Yep, agreed.
On another note, when I was down here yesterday I was excited to see/sense that the area is finally starting to feel dense and full. Walking along Bremner east of Lower Simcoe is starting to have a big city feel. When phase 3 (if that's what the office building component of Ice is called) is done, Bremner will have a nice little canyon terminating on the ACC.
And then when Harbour and 10 York are done, looking down York st from Bremner will be awesome as well.
Pretty pumped.
