It will be built... eventually.
Hey, it only took just under 50 years for them to build the Yonge line...
Thanks. So then no change -- that's what I thought.That is what they will commit when they get the revenue tools..
Well in 2030, the DRL proposal will be ~50 years old come 2030. So I guess we could say we're right on schedule![]()
The rest of Ontario will not tolerate yet more money going into the endless pit of Toronto transit.
This maybe a hard one for anyone who thinks you get a nose bleed when you go north of Eglinton but.............Toronto only has one-sixth of the provinces population and even the GTA is still less than half. Ontarians aren't going to accept Toronto getting blank cheques for it's infrastructure when Queen's Park only funds one-third the costs of transit infrastructure outside of the GTA. \
What do you mean? As far as I recall, that alignment was all underground south of O'Connor except perhaps for a brief daylighting as it passed the edge of the yard - and even then I'm not sure it popped above ground.Yes, but that was back in the days when people understood a subway could run in the open air, and still be a "subway". Nowadays, we tunnel under suburban waste grounds, hydro corridors, rail corridors, you name it. To do otherwise would be second class transit!
No benefit to routing through Greenwood Yard.
It's hard to be specific without concrete numbers but as a general rule we should always try to minimize costs as much as possible without compromising the central goal of the project.
Just because the DRL is seen to be very important doesn't mean it's a good idea to spend ~400m/km if we could get away with ~300m/km.
There's obviously a sentiment out there which thinks 'if we're spending 400m/km to build subways into nowheresville/York Region, the far busier downtown ought to deserve as much.' It's understandable but not necessarily very constructive.
I'd also add that, quite directly, opting for more expensive construction methods will directly reduce potential ridership since what you can afford will be proportionately shorter. Longer routs obviously attract more riders. If the DRL never goes past the Dundas West- Eglinton route, which is even itself unlikely, there's no way it'll ever significantly exceed Canada Line-esque capacities.
Yes, it is a choice. I'm as in favour of a DRL as anyone else here, but it's flat out wrong to think that it's somehow 'neccesary' or that, someday, a political leader will come to his or her senses and see that the DRL is the keystone to Toronto transit. It's not.
I could list a half a dozen transit lines in half a dozen cities which have FAR more severe overcrowding than anything Yonge could ever have, and for far longer portions of the day. When I lived in London I'd routinely have to wait 4-5 trains to go from Mile End to St. Pauls. Even in Toronto we can all think of streets which are constantly overcapacity.
Yonge will not get to a point where politicians somehow have no choice but to build the DRL. Peak-hour congestion is just an inevitable fact of life. We should do what we can to ameliorate it but it's simply not cost efficient to build our entire transit system around AM peak. All that will do is make sure everything's under-utilized ~95% of the week!
And Toronto will no longer tolerate being Ontario's money tree.
Toronto is drained of $11 Billion in taxes annually that are never reinvested in the city. So perhaps Toronto should abandon Ontario and take our $ Billions with us. With the savings we'd be able to save enough money to build a DRL and whatever else we want in no time.. Good luck fixing that massive hole in your budget, Ontario. It's gonna suck losing that massive annual subsidy nobody ever shows appreciation for.
Toronto extends far beyond north of Eglinton by the way. I only suffer from chronic nosebleeds north of Steeles![]()
The same Toronto that voted for Rob Ford is going to succeed from the province? The same apathetic, check-if-there's-a-pulse city I know and love? Next you'll be threatening that the city will take to the streets to demand transit and just funding! Yeah, not likely to happen either.
