BurlOak
Senior Member
This is what you are referring to. http://www.skyscrapercity.com/showthread.php?t=670156Why would you need a loop track? St. George doesn't have one. The net cost difference between having it south of Danforth and north of Danforth is nil, not some kind of astronomical add-on.
The idea is that once the whole thing is running on ATC, you could put the wye into play just like St. George with the interlining. During non-peak times, you could blend the service if there is room on the headway, so half the trains go directly downtown (there's an old DRL fantasy map by someone named dmz(?) floating around that I can't find that showed this better than I'm describing.)
I don't understand this stuff, but it appears the images in the link don't work, but when you look in google images, they are there. https://www.google.com/search?q=TRZ'S+DRL+PROPOSAL&source=lnms&tbm=isch&sa=X&ved=0ahUKEwi68tvhp-jaAhUr34MKHSGMBUAQ_AUICigB&biw=1366&bih=662
