BurlOak
Senior Member
According to the MOU between Ford and McGuinty, the line could be elevated near the Don Valley - which is a 4 km long stretch. The problem is that they actually spent no time trying to design the connected ECLRT/SRT. They just looked at ways of sabotaging Ford.Seriously?
There would have been plenty of time to fix the design between Don Mills and Laird before the line needed to go to tender, if they had not had to waste so much time with that ridiculous all underground LRT connected with the SLRT for $2 Billon more.
For the Leslie stop, it was Metrolinx who said that the portal in its current location was not possible. Again, it was their politicking that led to the wrong things being explored.
The choice was for Council or the Provincial Liberals to explore ways of improving transit. It's not my fault that the politics turned to "defeat Ford at all costs", instead of "how can we work with the most pro-subway Mayor in Toronto history to build more rapid transit". Ford, and then Tory, actually secured additional money, but it was the planning that went horribly awry and prevented the right things from being done.And I have clearly told you this several times before, just how long will it be before things finally sink in? The choice WAS NOT between building the Scarborough Subway with the current Eglinton LRT design or the all underground Eglinton LRT. It was between building the Finch, Sheppard, Eglinton and RT extension LRT's or wasting all that money on just the All underground Eglinton LRT connected to the SRT. Cancelling those three lines and putting all that money into a $2 Billion hole in the ground on Eglinton that would have saved maybe four minutes in travel time from Kennedy to Don Mills was not a better value as you obsessively keep claiming.
