innsertnamehere
I think everyone on this board agrees, but it isn't a disaster as is currently either.
Leslie shouldn't even have a stop.
It's now very clear where the stations are and where the stops are. I still think they should have ended the tunnel at Don Mills. It seems a more natural endpoint for the tunnelled portion.
Where the tunnel ends has absolutely no effect on operations. What does affect operations are traffic lights which do not have absolute transit priority. Since Leslie is a T intersection, placing the ROW on the south side of the street would make segment between Don Mills and Brentcliffe to be faster than a tunnel (since there is less air resistance above ground), not to mention orders of magnitude cheaper. They definitely made the right choice to have an at-grade ROW between the east portal of the main tunnel and the west portal of Don Mills (underground) station.
Tunnels are not the only form of grade separation, which is what the public seems to be forgetting. At-grade transit can still be grade separated, or it can alternatively operate just as well, with a few grade-crossings with priority.
If Metrolinx doesn't change the design to put the light rail on the south side, or build a grade separated interchange (like Bayview/Lawrence?) with the light rail in the middle, then the only remaining option is to ban left turns at this intersection. I don't think this would be a popular choice at all.
Yes, I'm aware that the current design will likely result in LRT delays at Leslie.
My point is that in order to eliminate this problem we do not need to build a tunnel (under a ravine, no less!), but merely to move the ROW to the side of the street. A similar change was made on the west end, where initially the line would have run in the median through Black Creek Drive. But the new design puts it on the north side of the street, with a bridge over Black Creek Drive. On the south side of Eglinton at Leslie, a bridge (or tunnel) would not be needed since there is no road to cross.
