Leo_Chan
Senior Member
At least all subway transfers are underground, the entire corridor is double tracked, and the platforms can support 3 car trains.They couldn't have been more short sighted on Eglinton if they tried
Part of the reason why I'll never truly appreciate this LRT project is because there were already plans in place for a subway along the western portion of Eglington back in the 90s. If we had just stayed the course, we would already have a subway along Eglington and probably be discussing an Eastward extension into Scarborough.I think it's inevitable that Eglinton will have to be split into 2 lines with the subway starting at OSC going west and the glorified streetcar going east. They couldn't have been more short sighted on Eglinton if they tried and it's 100% Miller's fault.
Yes, but Ontarians voted in Harris. Unfortunately the past is done.Part of the reason why I'll never truly appreciate this LRT project is because there were already plans in place for a subway along the western portion of Eglington back in the 90s. If we had just stayed the course, we would already have a subway along Eglington and probably be discussing an Eastward extension into Scarborough.
The cheaper solution that makes transit more efficient through Scarborough is to give the LRT railroad like priority at intersections. Similar to railroads they should then do the calculation to see if the risk at each intersection warrants a grade separation.I think it's inevitable that Eglinton will have to be split into 2 lines with the subway starting at OSC going west and the glorified streetcar going east. They couldn't have been more short sighted on Eglinton if they tried and it's 100% Miller's fault.
so the C-train solution... makes sense...though politically good luck...The cheaper solution that makes transit more efficient through Scarborough is to give the LRT railroad like priority at intersections. Similar to railroads they should then do the calculation to see if the risk at each intersection warrants a grade separation.
NO.... it would be another Line 4... forever a stub line due to political intrigueHypothetical scenario:
Let's say the Eglinton West subway in the 90s went ahead. Do you think the subway would have eventually been extended, first eastbound and then westbound? Or would they have kept the subway as it is, and built LRT on either side?
Toronto's Drivers Services, I mean Transportation Services, refuses to give priority to the 300+ people possible onboard the light rail vehicles because the politicians and bureaucrats don't want to upset the automobile disciples in charge. The 3 or 4 automobiles carries 1.3 to 1.6 on average need to go first when they make their left turns.The cheaper solution that makes transit more efficient through Scarborough is to give the LRT railroad like priority at intersections. Similar to railroads they should then do the calculation to see if the risk at each intersection warrants a grade separation.
Chicken and the egg imo. People are right that it would’ve been another stubway, because it would have kicked the can down the road of needing rapid transit along all of Eg by addressing the most pressing need first (bus congestion) just like Sheppard.Hypothetical scenario:
Eglinton Station:
Salvation Army building
Source: https://assets.metrolinx.com/image/...Eglinton_-_Mt_Pleasant_CLC_-_July_12_2023.pdf
The crosstown website has (finally) been relaunched. Now under Metrolinx's website:
Eglinton Crosstown LRT.What We're Building
Learn more about the stops and structures being built on the Eglinton Crosstown LRT.www.metrolinx.com
Construction notices can be found under "Get Involved" -> "Community Notices"
Kennedy Station
The station will include connections to:
- the GO Transit Stouffville Line,
- the TTC Scarborough RT,
