p5connex
Active Member
The main issue with Cumberland Terrace, specifically in terms of tower, no tower, and/or placement of towers, as well as the number of towers, is due primarily to the subway line running below the site. It comes into the site at a strange angle, leaving only a small portion available to be developed, where typical excavating and building methods are possible - otherwise, caissons that straddle the tunnels is required. This is very costly, and is often first thing that is pushed from the table.
The TTC will not allow that you simply build on top of their tunnels - there are maximum loads that the tunnel can take before you essentially need to build around the tunnel and put in caissons. This is one option that had been explored for CT, but it was scrapped/reconsidered because the hight costs associated.
p5
p5
