News   Apr 02, 2026
 2.4K     3
News   Apr 02, 2026
 1.1K     0
News   Apr 02, 2026
 2.6K     2
miWay Transit
I wonder who else mentioned that? 🤔
I don't buy the people are taking busses answer because the Dixie GO and other Milton line lots are PACKED
I'm inclined to believe more people along the Transitway connect or walk to the station compared to GO. According to the station numbers I do have from 2023, Lisgar GO to Dixie GO account for 2.2 mil. boardings, for an est. total ridership of 4.4 given probably 99% of trips are circular. Comparitavely, Transitway had 4 mil in 2025. That 4 mil figure is probably also excluding GO bus service.
It seems kind of insane that they seem to pull comparative numbers, but do mind the 2 year difference.
4 million is most likely the boardings for the entirety of 107 and 109, including on-street stops, rather than specific to boardings at the Transitway stations or CCTT.
How can you walk to Dixie when they don’t allow any housing around it. Erin meadows has some housing around it but instead of adding density recently it added another factory.
Once again the majority of the development is at square one with no go train. And some of the most protested amount of development (port credit) with all day go train.
For clarity, here is the full quote:
"We know that transitway ridership on the transitway at large, remains down to precovid levels, and we also know that that is likely tied to fact that we have not yet re-introduced the airport express. So we do know that when we are in the position to return that route, we expect that ridership and usage of the transitway will come back up. We are looking at an annual ridership on all of our transitway stations of approximately 3.94 million. So that is a significant number of riders that do rely on that corridor. There is intention within our planning group, to maximize it because it is a significant transit asset, and look to expand our frequency of express routes that use the corridor, and that will improve the ridership on transitway as well."
-Maureen Cosyn Heath, Director of Transit at MiWay
Sounds like it is including routes like 7 and 39 at Renforth, and 110 at CCTT and Erin Mills as well. Even with those routes included, 4 million still very surprising considering 100/107/109 not fully returned to normal, and GO numbers not included either.
If you look at stop ridership maps, the Winston Churchill and Erin Mills stations stick out in the west end, but east of Hurontario the Transitway gets overshadowed by corridors like Bloor and Dixie.
I always considered the Transitway more of regional/GO thing, so any meaningful MiWay ridership is a nice bonus, so I don't think they really need to overstate it.
Another passenger perspective you’ll never hear about in a board meeting.
This bus was delivered in spring 2025! Why has it deteriorated so fast?
This isn't deterioration. This is salt buildup. Everyone's boots and shoes walks around and picks up an ungodly amount of snow mixed with salt, and it melts on the bus leaving only the salt behind. There's not really much that can be done about this other than more routine cleaning. (And at an individual level, I recommend knocking your shoes on some pole or wall before boarding. Good practice all around!) I can't speak to how well MiWay does it compared to other bus agencies in the GTA, because I don't ride the bus often, but I suspect most bus agencies are similar. The times I have ridden MiWay at these times of years, I do often see pretty bad salt buildup. The salt buildup is mostly cosmetic, so it will eventually be cleaned without any problems afterwards.
Not to say "Oh it's whatever, get over it" because I don't like it either, its ugly- but cleaning can be pretty expensive, especially for something like buses which have to be taken out of service to be cleaned, leaving driving manpower and buses idling.
Listen to the noise I’m not talking about the dirt on the ground, which happens everywhere!
The whole time the engine was running, It sounded like there’s a jackhammer in the back with me.
Ah, my apologies. Didn't have audio on.
Unfortunately I'm no expert in engines... no clue what can be causing that or what it means.
Over at CPTDB, we have a post outlining service changes for February 23rd, 2026:
And further detail with this one:
Well, it's been announced officially, plus some other welcome service changes. With these changes, the 1 Dundas, 11 Westwood, and 101 Dundas Express enter the realm of all-day frequent routes, though Dundas is a bit of a "you win some you lose some" given the blended frequency. https://www.mississauga.ca/miway-transit/announcements/service-changes-start-on-monday-february-23/
MiWay Service Changes - 23 February, 2026
RouteChangeOld/New
1 DundasRouting changes1C Dundas removed; all trips will run via UTM and terminate/originate at Ridgeway with no service to South Common
1 DundasAM Peak: -31%*~11 min. -> 15 min.
1 DundasMidday: +9%*~16 min. -> 15 min.
1 DundasPM Peak: -6%*~14 min. -> 15 min.
1 DundasSaturday morning: -20%*~16 min. -> 20 min.
1 DundasSaturday afternoon: -5%*~19 min. -> 20 min.
1 DundasSaturday evening: -20%*~16 min. -> 20 min.
1 DundasSunday morning: +17%*~24 min. -> 20 min.
1 DundasSunday afternoon: +20%*~25 min. -> 20 min.
1 DundasSunday evening: increase in service20-40 min. -> 20 min.
101 Dundas Express (it doesn't numerically fit but it makes sense here)Routing changesNo service to South Common, all trips now run the 101A Dundas Express pattern
101 Dundas ExpressAM Peak: +0%*~15 min. (with high variation) -> 15 min.
101 Dundas ExpressMidday: +47%*22 min. -> 15 min.
101 Dundas ExpressPM Peak: +0%*~15 min. (with high variation) -> 15 min.
101 Dundas ExpressSaturday: +10%*~22 min. -> 20 min.
48 Erin Mills (this also doesn't fit numerically but still makes sense)Routing changeRoute will extend from South Common to UTM, (partly) making up lost 1C/101 service
48 Erin MillsAM Peak: +104%45 min. -> 22 min.
48 Erin MillsMidday: +67%50 min. -> 30 min.
48 Erin MillsPM Peak: +108%50 min. -> 24 min.
48 Erin MillsEvening: +14%40 min. -> 35 min.
48 Erin MillsSaturday morning: +18%45 min. -> 38 min.
48 Erin MillsSaturday afternoon: +20%50 min. -> 40 min.
48 Erin MillsSaturday evening: +32%45 min. -> 34 min.
48 Erin MillsSunday morning: +29%45 min. -> 35 min.
48 Erin MillsSunday afternoon: +32%50 min. -> 38 min.
48 Erin MillsSunday evening: +20%40 min. -> 32 min.
3 BloorSaturday: +40%28 min. -> 20 min.
3 BloorSaturday evening: +44%26 min. -> 18 min.
3 BloorSunday afternoon: +27%28 min. -> 22 min.
3 BloorSunday evening: +27%28 min. -> 22 min.
5 DixieSunday eveningone later trip
7 AirportSaturday morningone earlier trip
7 AirportWeekend eveningsone later trip on both Saturdays and Sundays
11 WestwoodPeak Periods: +18%13 min. -> 11 min.
11 WestwoodMidday: +33%20 min. -> 15 min.
11 WestwoodSaturday: +44%26 min. -> 18 min.
11 WestwoodSunday: +44%26 min. -> 18 min.
26 BurnhamthorpeRouting changeThe route will run in the opposite direction around South Common due to the 48 extension
28 ConfederationMidday: +30%30 min. -> 23 min.
42 DerrySunday eveningone later trip
103 Hurontario ExpressSunday morningone earlier trip
109 Meadowvale ExpressEvening: +33%20 min. -> 15 min.
109 Meadowvale ExpressSaturday afternoon: +11%20 min. -> 18 min.
*blended frequency, the branch frequency is a robust increase
The routing change - the 1C Dundas is removed, as is the 101 Dundas to Erin Mills; both of these routes will have a single branch reaching UTM, before continuing to Ridgeway Drive. Route 48 will be extended to UTM, and the 26 will switch directions at South Common.
Minor adjustments:
  • 1 Dundas (all days)
  • 3 Bloor (weekdays, Saturdays)
  • 11 Westwood (all days)
  • 15 Drew (weekdays)
  • 16 Malton (all days)
  • 22 Finch (all days)
  • 24 Northwest (weekdays)
  • 28 Confederation (all days)
  • 30 Rexdale (weekdays, Saturdays)
  • 38 Creditview (weekdays)
  • 39 Britannia (weekends)
  • 61 Mavis (weekdays, Sundays)
  • 66 McLaughlin (weekdays, Sundays)
  • 101 Dundas Express (weekdays, Saturdays)
  • 108 Financial Express (weekdays)
  • 109 Meadowvale Express (all days)
RouteChangeOld/New
Minor adjustments:
Thanks for the detailed chart. It makes it easier for me to read the changes!
Although MiWay's service change announcements have become more detailed lately, they still happen to miss things. In some cases I'm not so sure it's intentional, but in other cases it seems deliberate. Such is the case when service cuts are veiled as "schedule adjustments". This is the case for routes 61 and 66 which will see reduced rush hour service. Previously in October there was a substantial cut to the route 5's weekday PM rush hour service, both in terms of frequency and span of peak service, despite this there wasn't even a mention of changes to the route 5.
Going back to this service change the 61 loses a bus in both peak periods and the result is the peak frequency being reduced from 12 minutes to every 13-14 minutes. The 66 loses an AM peak bus and two PM peak buses and as a result goes from every 9 minutes to every 10-12 minutes. No change to off-peak service.
As part of the Dundas service changes they also fail to mention increased service span, with service now running interrupted through Friday night into Saturday. Sunday service also begins earlier and ends later, of particular note is that the westbound service now begins an hour and a half earlier.
The 28 also receives an additional southbound trip on Sunday evening thereby extending service. The 3 also receives extended Sunday service in both directions by half hour as part of its changes. Neither of which are mentioned in the service change announcement.
As far as this service change goes I would say it is one of the more monumental changes implemented recently. The re-alignment of the Dundas service is long overdue especially considering the re-alignment of Oakville Transit's Dundas service in June of last year. While rush hour service is reduced the elimination of the branched service design should produce more even loads. The branched service design also produced atrociously blended headways on the trunk section and the result was very poor distribution of loads.
What is disappointing is that both the 1 and 101 will run with 10 buses during the midday while providing the same 15 minute headways which tells us the 101 is really not producing meaningful travel time savings during this time. I will conduct a proper schedule comparison and post the results here later.
For those who want to geek out further on the changes to Dundas I've produced a series of data visualizations comparing resource allocations (vehicles in service) and also one for headways eastbound as screened from Hurontario St.
• Dundas Weekday Vehicle Block Visualization
• Dundas Weekday Headway Visualization
• Dundas Saturday Vehicle Block Visualization
• Dundas Saturday Headway Visualization
• Dundas Sunday Vehicle Block Visualization
• Dundas Sunday Headway Visualization
