News   Nov 28, 2024
 165     0
News   Nov 28, 2024
 332     1
News   Nov 27, 2024
 1.1K     4
Metrolinx: Bombardier Flexity Freedom & Alstom Citadis Spirit LRVs
I didn't write that. You've attributed someone else's words to me.
Wasn't applying it to you, but to Steve. Sorry for that.
For one who loves posting links, I am surprised you haven't read this how wheel gauges can be change on the fly from one system to another. I had this happen to me going from France to Spain.
I'm fully aware of it. It's fraught with problems, and Spain has accepted the need to adopt to standard gauge on any new-builds, especially those that go cross-border. Russia and China do something similar on the Trans-Siberian express, which is anything but 'express' but I digress.
Changing wheels on the Trans Siberian railway - Nomadic Boys
Meantime:
Since 1992, all high-speed rail lines in Spain have been built to standard gauge, 1,435mm, providing direct connections without break-of-gauge with the French railway system. The high speed line that was projected to run from Madrid to Lisbon was also to have been built at this gauge.
Track gauge in Spain - Wikipedia
https://en.wikipedia.org/wiki/Track_gauge_in_Spain
As for the automatic wheelset waist trimming and nail clipping machine, is this really in your realm of arguing your point?
174119
If it wasn't for the fact that TTC was in its 3rd year of rebuilding the system to the new standards, TTC would have standard gauge on the surface today.
I take your "3rd year" to mean third inception? The TTC is also stuck with much tighter radii than standard UIC practice and grades that many suppliers don't build for. Even if the TTC had standard gauge track and flexibility in voltage scaling and control systems, it would only mean TTC stock could run through onto other systems, and highly unlikely that could be reciprocated. It would greatly help with running onto the LRT lines, however.
And for the subway, standard gauge could greatly assist interlining with LRTs and mainlines, as is done in other cities in Canada, and many in Europe.
Of course they'd use standard gauge given a fresh start. I've made it very clear prior though that it's too late to change what's already been done, they're bound to their heritage choices.
My point has always been the extra costs of having made that choice and the straight-jacket of expanding into interlining with other systems, sharing track and buying equipment.
There is no traction xfrmr on DC vehicles. That is one of the previous advantages to DC traction. With modern xfrmr design (Siemens is far ahead of the competition with core configuration) that weight penalty has been all but eliminated. Switching power supplies also minimize the difference (the higher the conversion frequency, the smaller the core necessary, albeit other factors limit the highest freq that can be used without significant core losses).
In the case of DC to DC, a simple switching stack is all that's necessary. The basic circuit is very simple and cheap.(The voltage sensing is just done with inexpensive but 'fast' diodes) For a streetcar/LRV, the unit would be about the size of a suitcase including all the automatic sensing to do the switch instantaneously. The unit will also double as a 'clamp-regulator' on voltage variations on the line. This is very similar to computer power supplies that can be plugged into 120V or 240V sources with no change needed other than the plug, or the plug-in chargers for cell/i phones and devices.
In the event, older pre solid-state control motors will run just fine on a variance of 600-750V. The higher voltage will render 1.3X more traction torque and power, all other things staying the same. When mainline third rail trains in London run on the Underground lines (still done to this day) they do so on the lower Underground voltage (660v vs 750v). That's a perfect illustration of interoperability as I describe earlier, not available to Toronto due to the track gauge difference.
Here's another:
There's a lot more examples, but that suffices to make the point...to those that care to see.
I'm not sure what any of that has to do with the Flexity cars, both the ones for the legacy system and the Flexity Freedoms. They are using AC traction motors, not DC.
A traction motor uses reformed AC from a DC source. A "traction transformer" is used to...I'm short on time, here's a published explanation:
Traction transformers
Traction transformers are critical components in the traction chain, affecting both train performance and operator services. ABB supplies traction transformers for all applications: high-speed, commuter and regional trains, locomotives, tram-trains and AC metros offering different designs in terms of size, weight and power ratings. They can be mounted either in the machine room of the train, on the roof or under the floor, providing maximum flexibility and reliability in single and multiphase systems.
Most of the world’s train manufacturers and rail operators rely on ABB traction transformers.
In fact Siemens have the edge right now, but I digress. (As to how they've gotten it down to the size they have is a company secret)
main-qimg-52fe60d63a7754b884af8b145d6584af
A traction transformer is specifically designed to transform power from the locomotives overhead power that is delivered to the electric motors. The motors turn the wheels of a locomotive. Those are called the traction motors because the turning of the wheels uses the friction or resistance of the surface of the wheel in order to “grab” the surface of the rail. That is simply traction.
You can't put DC through an xfrmr, save in special instances where core saturation is the intention (edit: With caveats, the DC must be superimposed on a carrier AC)(resulting in massive power loss in the form of heat). (The purpose of this is usually for regulation at the expense of efficiency).(It's done magnificently nowadays with solid-state control either side of the xfrmr, and then the DC is reconstituted into AC for motor use.
DC systems, almost invariably used on streetcars and subways, don't use "traction transformers". They have solid state 'multivibrators' (an old term still used from the days of electro-mechanical devices) to turn the DC into a form of AC, in modern traction motors, almost invariably three phase AC...the same way solar cell arrays do for use as house and street current (the phase form is selectable, either single or triple) and the motor speed is controlled by both "chopping" of the applied voltage and synchronous variability in terms of the frequency of the reconstituted AC from DC.
Ironically, in the now almost universal single phase AC catenary use, it's rectified after the traction xfrmr! into DC, and most often reconstituted before or after (sometimes both) the control circuits, and then applied to the traction motors.
There's many incredibly good engineering papers on-line.
I'm most familiar with toroid transformers, being deeply involved in their design, manufacture and distribution, albeit my emphasis is on audio output ones. Power circuits are mundane to audio nerds. What Siemens are doing (any modern traction xfrmrs are a form of toroid) is intriguing. I leave it at that.
Lots here:
The point is that running a DC powered vehicle eliminates the need for a traction transformer, albeit there are prototypical exceptions to that. And traction transformers, early ones being a massive weight, are now much smaller, and the reconstitution of the line frequency from, say, 60Hz to 600Hz before it's even transformed reduces the size/weight of the core geometrically. (Computer 'switching' supplies do this, to make them small and light, but still offer isolation from the line for safety)(some failing on the latter, btw)
That's the reason why aircraft control systems have used much higher line frequencies, It not only reduces the core size/weight of needed xfrmrs, it does for the motors too.
Why we use 400Hz Power Supply in Aircraft?
^ And using Flexities would really add that much more time to Eglinton? Has a comparison time ever been put forward?
Still disappointed we are using Flexities for Eglinton. They have way slower alighting speeds than the Siemens S70s because of the removal of what would be one set of double doors.
Do we even know what the door configuration for Finch West is? I thought Citadis Spirit units were customizable. Looks to me that a 30-metre Citadis Spirit has 4 doors, like the 30-metre Flexity.
If they use the same configuration as Ottawa, you get 7 doors on a 48.5-metre car. That would be equivalent to 4.3 doors on a 30-metre car.
Surely 4 doors instead of 4.3 doors is "slightly lower alighting speeds" not "way lower alighting speeds".
I'd be tempted to say "imperceptibly lower alighting speeds"!
Is there an indication somewhere that this will be a problem?
Less doors is generally gonna mean more time.
Given the very small difference, it would theoretically mean a small increase.
It was the "way more" I was objecting too ... it's a rounding error, surely.
The 100% low floor design makes the streetcars take forever for alighting when crowded because people are forced out and forced to squeeze through tons of tight spaces.
That's not what I'm seeing. I regularly still take both, and the amount of time for people to climb the stairs is significant. Especially in the front, by the time the person gets from behind the white line, all the way down the stairs, and then those there have to come in, and up the stairs. It's not much better in the back - especially as the back doors can't even close until after everyone has gotten off the stairs!
It's not a small difference its got 3/4 the doors.
And I am not referring to the bad legacy streetcars, I'm referring to a 70% low floor design like the Siemens S70.
Maybe I'm confused then. An s70 in a 30m configuration like say in San Diego, Portland, or any other variety of American cities also only has 4 doors. How is it any different than a 4 door flexity or citadis, other than being 70% low floor
Or is your point that because there's a single door at each end module rather than a double it's worse? I don't think it will make a massive difference, although it's less optimal. Really the distance between where you're sitting/standing and the nearest exit makes the biggest difference in people getting off the train and the next group getting on.
Yep thats what I'm referring to and the difference is actually pretty big. People can enter and exit a double door at the same time. Thats not true for a single door.
What is the width of the doors on the S70, though? I can't seem to find any information on them online.
To my eye, they don't appear to be as wide as the double-doors on the Flexities. But without an actual measurement I'm not willing to claim that one is bigger than the other.
So... Why is Metrolinx still so infatuated with Alstom?
'Unreliable' LRT trains can't handle Ottawa winters, internal reports reveal
Here in KW with Bombardier vehicles we haven't had these kinds of issues.
