So remind me why they need to cross the 401 to use the CP tracks? Why not just extend the GO sub past Oshawa beside the Kingston Sub?
Because the existing development where the customers are, and the most promising lications for further development, are almost totally north of the 401. The CN line offers lower marketability and less value provided.
I would hope that members of a forum called "urban Toronto" would understand the value of building a rail station close to ( approx 1 km) a city's central core rather than through low densities.
I had never considered via relocating to ritson station but both would be extremely helpful in rerevitalizing central oshawa.
Once GO RER is a thing, I think they should move York University station north to Ste
The problem is how do you get VIA back onto the CN line in the east.
Also, VIA doesnt use the GO tracks east of Pickering. It stays on CN tracks to the south.
Not that it wouldnt be feasible, but im not sure Metrolinx would want them using them, nor VIA want to since they are only double tracked. VIA would easily get stuck behind a GO-RER train making all stops.
The Bellville sub has a few places where they connect to the Kingston Sub, and one is near Cobourg.
You could also build one at Stevenson Rd in Newcastle.
That might be true, but the GO tracks for the Bowmanville extension will be separate from CPs and only exist in their corridor, they won't be using CP's tracks.
So then there would have to be another connection to the GO line, which is slated for single track initially.
I simply just don't see this happening, VIA will most likely continue to use the existing Oshawa GO station for quite some time.
Given the penny wise, pound poor way we plan rail passenger in this country, I agree with you. I raised the possibility in the context of “If I were running things”.
A Durham GO-VIA hub is right headed. Alas, we will be stuck with it being at the current Oshawa location, because otherwise the brand-new Oshawa depot will be seen as a white elephant. (which it is).
A CN-CP connecting track (with 401 overpass) out around Townline Road would not be expensive in the scheme of things. Nor would an interlocking to put VIA back on the Kingston Sub due west of the Oshawa platform. The operational constraints are no bigger than what VIA is proposing to do with HFR, putting it on the Stouffville line from Agincourt to Scarborough Jct.
Personally, I would still like to see that hub on the CP line, much closer to downtown Oshawa.
By extending the GO train to Cobourg would allow people to transfer to VIA without having to go to Oshawa and then travel back east.
How hard is it to build a cross over track when the the tracks are right beside each other? You would need to integrate the CTC but you have to build it for the the new tracks anyways.
But it would be helpful to have a way to get trains to and from that line in case there is a blockage or derailment. Which is why either have a cross over with the Belleville Sub or connect to the Kingston Sub at Cobourg.
This is incorrect. Another track or pair of tracks will be added to CP's, but they will be linked at several interlockings along the way to maximize the capacity of the corridor.
What are the chances of a go bus route going from oakville to kitchener via Sheridan College, Trafalgar/407, Milton, 401/25, Aberfoyle, U of Guelph, Highway 7, Laurier and U of Waterloo. Serving 4 post secondary institutions and having better connectivity on Trafalgar and Halton as a whole is something ML would be down for right? I wish this would happen.
Hmmm, I mapped out a route that would meet your specifications: The dots are of no significance, just spots I used to draw the line.
This is going to be fun
Lakeshore West passengers: During the weekend of March 12-14, some evening and morning GO train service between Union Station and Port Credit GO on the Lakeshore West line will be suspended due to critical work to upgrade our rail infrastructure.
- From Friday late evening to Saturday early morning and Saturday late evening to Sunday morning, express buses will operate between Union Station Bus Terminal and Port Credit GO.
- Trains will continue to operate between Port Credit and Aldershot GO stations throughout the entire weekend.
- It’s important to double check schedules and use triplinx.ca to plan your trip. Plan your trip here or see the full schedules here. Be sure to consult gotransit.com often for updates.
Friday, March 12:
- There will be no train service between Port Credit GO and Union Station beginning at 10:30 p.m. until the end of service. GO bus service will pick up customers at Port Credit or Union Station Bus Terminal and travel express.
- GO Buses will depart 4 minutes later than train times at Port Credit GO.
- GO Buses will depart 10-15 minutes earlier than train times at Union Station Bus Terminal.
- Trains departing Port Credit GO to Aldershot GO will depart 5 minutes later.
Saturday, March 13:
- Regular train service will be in effect between 8 a.m. and 10 p.m.
- There will be no train service between Port Credit GO and Union Station before 8 a.m. and after 10:00 p.m. until the end of service. GO bus service will pick up customers at Port Credit or Union Station Bus Terminal and travel express.
- GO Buses will depart 9 minutes later than train times at Port Credit GO.
- GO Buses will depart 15 minutes earlier than train times at Union Station Bus Terminal.
Sunday, March 14:
- There will be no train service between Port Credit GO and Union Station before 9:30 a.m. GO bus service will pick up customers at Port Credit or Union Station Bus Terminal and travel express.
- Regular train service will resume at 9:30 a.m.
There will be no train service at Long Branch, Mimico and Exhibition GO stations while this track work takes place. If you need to get to/from these stations during this time, we encourage customers to explore alternative transit options through our partners at MiWay and TTC.
The new GO bus terminal at Union Station is located at 81 Bay Street in Toronto at the north-east corner of Bay and Lake Shore Blvd.
- To access the new terminal from outside – enter via the main entrance on Lake Shore Blvd., just east of Bay Street or the entrance on the east side of Bay Street, across from Scotiabank Arena.
- If you’re coming from Union Station, you can take the indoor pedestrian bridge over Bay Street that connects to the bus terminal from Scotiabank Arena.
- Learn more about boarding at the new Union Station Bus Terminal.
- Please check departure boards before proceeding to your boarding zone and gate.
You should also know:
- Customers connecting at Union Station between Lakeshore East and Lakeshore West trains may experience delays during scheduled service suspension due to the schedule changes required to accommodate this work.
- Customers with accessibility needs can access the south platform at Port Credit GO using the accessibility ramp located beside the Kiss & Ride.
- Parking is currently limited at Port Credit GO due to construction related to the Hurontario LRT. If you are travelling from this area and have issues finding parking, please park at Long Branch GO or Clarkson GO.
This construction work is part of important upgrades to aged rail infrastructure. These upgrades will improve train speeds, service life and reliability, allowing us to provide better service to you in the future.
Now take all those disruptions and mue toltiply them wholesale when they FINALLY decide that they want catenary trains and have to close down all the lines again to put up the polls and wires as opposed to doing it now.
There's some forward planning for ya.
