The province intends to award a contract for the entire $16.8-billion GO expansion program, including the Union platform reconfiguration, by spring 2020.
Also, although freight trains don't travel through the platforms under the train shed, isn't the issue of freight trains passing by other GO platforms relevant in terms of how they make level board work? Or maybe GO trains could be equipped with draw bridges? I'm sure I've seen them on other train sets. @smallspy @crs1026
Do freight trains have to stop at Union? Can we make it a passenger train only station?
If you look at posting above or back a few pages, you will see update photos on Bramalea by me. Exhibition is still dead in the water. Was by Maple New Year Eve and looks like nothing taking place, but hard to see in the dark and rain if anything is taking place.Does anyone have any updates on some of the lesser-known GO transit rail expansion projects?
For example:
-Don Yard (to be completed Dec 2018)
-Weston Sub 4th track from 427 to Nickel
-Stations (Exhibition, Oriole, Maple, Bramalea, etc)
-Bloomington extension
Right now, very few freight trains run through Union Station, and those that do always pass by on the far south track (that has no platform). Therefore, they aren't that relevant when discussing platform sizes at Union Station. What is of more concern is the size of the other types of passenger trains (VIA, AMTK, and potentially ONR) that use or will use the station.
I know that freight trains rarely pass through Union and only use the southern most track (and until the spur to the water treatment facility in the Port Lands is restored there's no regular service).
So I assume that the Union platforms will have very tight clearances and be level, but some platforms at other stations couldn't match that because freight trains still may need to go by at those other stations? In other words, the closest example I can think of is the UPX platforms on the Kitchener Line. Could a freight train if it had to go by the UPX platforms at Weston and Bloor?
http://forum.skyscraperpage.com/showthread.php?t=231799[...]
The Solution:
Siemens has developed a deployable gap-filler, which is now in service on Florida's BrightLine:
• Video Link
These allow for high platforms to be built directly on the mainline without need for gauntlet tracks or platform extenders, and freight trains can roll through these stations at full speed:
(skip to 20 seconds into this video)
• Video Link
This solution solves all the problems with platform heights. There don't need to be any infrastructure improvements. There don't need to be any special tracks for station platforms. There don't need to be wheelchair lifts, steps, or high-blocks. The only moving parts are contained within the train cars, so they can be actively maintained at the same schedule as the doors themselves.
I propose that every new passenger rail system be designed to use high-platforms, 48-51 inches tall, and use active gap-fillers to make every platform a level-boarding platform.
For busy rail corridors, bi-level cars can still function at high-level platforms, such as New Jersey Transit currently uses:
Another way to do bi-level cars is to go straight up, where space allows it. This would mean that passengers with disabilities could still move between cars easily on the bottom floor, and the top floor could be used for observation areas, just like in the Colorado Rail Car Ultra Domes, which are 18-feet tall (meaning they can go anywhere a double-stack container train can):
Most importantly, Siemens - the manufactuer of the Brightline cars - is set to manufacture 137 cars for Illinois and California for corridor service, replacing an order for bi-level cars. These types of passenger cars are also well-situated to be the car-of-choice for Amtrak's next long-distance fleet, replacing older cars on their long-distance trains. If these cars become that ubiquitous, it would be extremely easy to include the same gap-fillers in all these new cars (or retrofit them into existing Siemens cars). This would create a national standard platform height and eliminate all of the complicated and less-effective solutions that have been deployed throughout the non-Northeast Corridor parts of the country.
For more reading on how complicated platform heights can be, read this post of the Caltrans HSR Compatibility Blog:
http://caltrain-hsr.blogspot.com/200...VN24vHSWVqM2VM
It's not that simple, or that would have been done from the start.Just extend the sill as far as is prudent, as a fixed structure.
https://www.arema.org/files/library...ht_Manual-High_Speed_Passenger_Rail_Lines.pdfAUTOMATED HIGH LEVEL PLATFORM RETRACTABLE EDGE FEASIBILITY TO ACCOMMODATE WIDE LOAD PASSENGER FREIGHT MANUAL ON HIGH SPEED PASSENGER RAIL LINES Author: Edward La Guardia P.E. Author: Toby Fauber AICP
INTRODUCTION One of the major challenges facing passenger rail organizations today is the upgrading and rebuilding of passenger stations, particularly passenger platforms. The design considerations relating to passenger boarding are level boarding to reduce dwell time and for compliance with the Americans with Disabilities Act (ADA). One of the ways in which this is regularly being accomplished is through the construction of full-length highlevel platforms at stations. At many stations, high-level platforms have replaced traditional low-level or ground-level passenger platforms because high-level platforms provide direct boarding for large numbers of passengers along with easy, unrestricted access to trains for people with physical disabilities. Throughout the country, the common passenger rail right of way is typically either a shared passenger/freight corridor or a freight right of way with passenger service being hosted by the owner. This creates inherent challenges in meeting the needs of both operations, especially when ADA compliance and high-level platforms are part of the system. Where freight and passenger service operate together, high-level platforms create physical conflicts in the dynamic operating envelope of freight railroads that have wide load freight movements. Over the years, multiple options to alleviate the conflict while attempting to provide level boarding for passenger access and the requirements of ADA have been developed. These options include freight by-pass tracks, gauntlet tracks, and manual flip-up platform edges.
To address these issues, PennDOT conducted a study to identify andevaluate the feasibility of alternatives to traditional manual flip-up edge installations. Through this study, several creative and technologically advanced were identified that eliminate many of the issues present in high platform and freight movement conflicts The preliminary set of alternative approaches were as follows: 1. Powered Lifted Edge 2. Manual Lifted Edge 3. Vertical Rail Traverse 4. Accordion Fold Platform 5. Telescoping Edge 6. Flip-Down Edge 7. Drum and Spring Conveyor 8. Mini High Platform 9. Swing-Out Cam Follower 10. Mini High Scissor Lift Of the 10 options listed above, seven options were dismissed due to their inability to perform in all weather environments. There were three options that remained for further evaluation. These options were the lift edge, lowered edge and telescoping edge. These options were ranked as follows: Lift edge – most durable and safety advantages Lowered edge – less reliable and no safety edge Telescoping edge – extensive platform modifications, not durable in harsh weather, poor safety features
Just curious, how you do you find this stuff out? Do you view all development applications and committee/board meeting agendas?Site plan approval submitted yesterday to relocate Oriole GO Station to 2760 Old Leslie Street. This is the location of the TTC Leslie Station Parking Lot. The site is located adjacent to the bus terminal entrance of Leslie Subway Station which would greatly improve the TTC/GO connection.
The City's development projects webpage, filter the search by recently submitted applications. This tool shows all development projects within the City of Toronto. Because this is only a site plan application and not a major planning application it likely won't go to a committee of council for approval.Just curious, how you do you find this stuff out? Do you view all development applications and committee/board meeting agendas?
