 1.4K     6
We are getting bare bones stations. There are no elaborate buildings or full canopy coverage or granite platforms....... 232M per station for what we are getting is absurd.
Indeed it seems like an issue of quantity over quality (as well as Metrolinx's usual overhead cost and project management bloat). At St Clair / Old Weston, instead of getting a 3-car UPX platform, we're getting a 12-car platform. Future proofing is important to consider in any design, but there always needs to be a realistic tradeoff with the upfront cost. If we expected UP Express trains to be 12 cars long within a few years of opening then it would absolutely make sense to build the station that big. But if there are no current plans to run 12-car UP Express trains, it would presumably make more sense to design the station as a 12-car station, but then only actually build a 3-car portion of that design. As part of the construction, the track layout would be shifted such that the platforms could be extended to 12 cars in the future without requiring major infrastructure work.
I mean, compare the average GO station to an average European station, and what we deem "bare bones" would be considered elaborate in most European countries. Tunnels going under platforms, rail lines, etc.
The tunnels are not 'tunneled'. They are pre-fab boxes, essentially large culverts, that are placed, typically with rapid cut and cover.
That and long, but plain platforms with snow-melt, lighting and shelters do not cost anywhere near 233M to build. I assure you, nowhere close, even 1/2 that much is an excessive ask.
Local media article about the Bowmanville Extension.
Update: the meeting happened on January 6th per this post on Metrolinx's website.
lol people are going to be so pissed off with that especially with the Simcoe closure for 2 years. Just read a December community event was moved from in-person to online on the advice of authorities because of an anonymous threat.
Europe is a big continent with many different countries. I can't speak for all of them, but I have lived and worked in the Netherlands, and they are actively grade separating as many crossings as possible, just like Metrolinx. The fact that Metrolinx grade-separates pedestrian crossings is not the main issue here.
If you want, you could maybe suggest they should be using more overpasses than underpasses, which might be cheaper. For example at Maple station, they built a long tunnel from the elevated bus terminal:
capture3-jpg.409944
Rather than building an overpass that would have reduced the amount of elevators and stairs required:
capture2-jpg.409890
capture3-jpg.409944
capture2-jpg.409890
That's defintley something I noticed while in England, was the use of pedestrian overpasses at train stations vs underground.
(Making effort to forget painful memories of schlepping suitcase up and down steep and ancient stairways in exotic overseas rail stations)
Stairways vs tunnels are a simple exercise in cost comparison. The UK model may not be appropriate from an accessibility perspective.
I have no problem with the expense of making stations accessible. One can point to many places in the world where they are not, but one can also point to the efforts elsewhere to incrementally correct that. In this case we are discussing new stations built from scratch and I would not want to omit accessibility amenities from any new station.
What I do object to is the size and massing of the on platform structures, which have far more metal and concrete and wiring than most. Much more complex to build, more trades, more materials, more time, more maintenance. And for what? As we are looking ahead to 2WAD with headways where no one will have to shelter for very long, it seems we could omit a lot of that. I would keep snowmelt, but not much more.
I am quite OK with traditional GO glass wall mini shelters and oversized bus shelters.
A good example of unnecessary embellishment would be the original platforms and station buildings at Milliken and Agincourt versus the new. Similarly the original Bloor versus the new, minus the UP element.
Certain "key destination" stations might warrant the full treatment - Brampton, Guelph, Oakville for example. But not the intermediate commuter stops.
PS - Per the wonderful book Metropolitan Corridor, when the steam era commuter lines were built, stations and platform shelters were often built only on the inbound-side platform of American commuter lines. There was no need for shelters on the outbound sides, because nobody hung around after getting off the train. We are looking at 2-way transit rather than peak commuter trains, but that parsimony should be kept in mind.
The decision between pedestrian overpasses and pedestrian underpasses has very little to do with accessibility. Obviously both options will include the necessary step-free circulation, which usually consists of an elevator.
Underpasses usually have less elevation change for pedestrians than overpasses, which may increase the percentage of people who choose to use the elevator rather than the stairs. However, in some cases such as the connection to the Maple Station bus terminal, an underpass actually has more elevation change than an overpass.
This really is getting to be a comical joke.
Not only regarding the amount that's being spent for bare-minimum boned stations, but the amount of time it takes to construct a simple GO stations is laughably pathetic as well.
I'm starting to get more serious in my previous light-hearted assertions of outsourcing the construction of stations to Europeans, because we in Ontario truly dont know what we're doing with transit infrastructure construction if this what keeps going on.
I’m also irked about them having to come back to do more work to eventually raise the platforms to level floor height on all these recently built platforms, instead of modifying the coaches now to work with a level height platform and not having to raise all these platforms.
I thought they were sort of roughing in high-floor platforms.
My assumption was that the reason they're building all these platforms with knee-high concrete cuffing around the walls and pillars is that someday they will raise the height of the platform to that level, and this saves them having to deal with conflicts at that stage. (All the glass and all the electronic fixtures are already at an appropriate height, etc.) They'll have to rework things like stairways and raise the heights of doorways, but that's easier than rebuilding the whole platform.
To illustrate, Weston Station when it was under construction.
I'll differ somewhat here.
I don't mind extra elaboration, particularly full platform canopy coverage, and heated waiting areas for winter.
Sure, some routes will hopefully be every 15 minutes in the next few years (though not all), but delays happen, off-peak services will likely be less frequent at times, but also.....
Do you really want to get rained on on your way to the 'shelter'? Temperatures can be extreme at times, and unexpected as well.
I don't mind paying for better amenitization or a bit of aesthetic enhancement.
What I mind is paying serious coin, excessive coin, that should come with all of the above and more, for considerably less.
At the price points quoted, the platforms need to be granite, there needs to be full canopy coverage with some artistic oeuvre, I want elegant light fixtures, and the seats better recline, and some with tush warmers and I want my damned escalators. LOL
I will gladly meet you in the middle of the platform on this. Nothing wrong with shelter if it can be erected and maintained in a more spartan manner.
When I look at the elaborate flashings and trim on the most recently constructed platforms, and the incredibly plodding pace at which some have been built over the last few years, I definitely feel that directionally things should be kept simpler.
A good template I would offer would be the Scarborough station.... there is a roof level shelter in the middle of the platform, but traditional bus shelters towards the ends of the platform. From my observation, the limits to the roofing does not discourage people from spreading along the entire platform. There is lots of standing room under the roofed area.... but precious few benches. The roof and walls make the platform narrower and therefore less room for benches. If we are going to provide shelter, benches are desirable. (there are more seats in the bus shelters than under the roofed area). The tunnels have ramps which is a good addition to the elevators.
But having said that, my home station is Mimico and I have never minded its austerity. OK, on bad days one has to push through the folks who shelter at the top of the stairs, so some people want a roof. But building something massive end to end is just not needed.
Cup holders. Don't forget the cup holders.
I'm very grateful to you for posting this shot, as it shows just the point in time to make my point that there is overbuild. Maybe these are small ticket items for the Smarttrack stations, but it makes me wonder.
1 - Would we be disappointed if the platform had only a base flat roof without the strapping and flashing?
2 - That flashing requires some sort of underlying particle board (visible in yellow at the back) and then trim on top, Again, can it all be dispensed with?
3 - Similarly, the fancy shiny soffit on the underside? The exposed underside of the roof would suffice, and make the inevitable access to all the conduit that much more efficient. (Had there not been so much conduit, there would have been fewer flashing installers standing around waiting to get started - that flashing took months to get done - I have observed a lot of this.)
4 - Just where do all those stormwater drains go? Directly into ground I hope. But is there a roof style that would reduce the need for having so much of that? How much of a buried drain system does the platform have - and could there be less?
5 - The barriers protecting the accessible platform prevent people from walking down the platform, it's a pinch point for walking. Why not just ramp the ends with a handrail parallel to the tracks?
6 - Do we need fully sealed waiting areas with power outlets and heating? Could a windbreak suffice?
Perhaps someone more educated on level boarding can tell me, but I don't understand why they don't just build the platforms at level height (where possible, I know the freight width issues) and have passengers board with a wide step instead of a step up. To me, it sounds like a sidegrade at worst, but you don't have to go back and raise the platforms again when the gap is filled on the car side.
