Northern Light
When they design a cycling and pedestrian path based on "regulations". Likely to "slow" down cyclists...
Walter, that is not a cycling path; and it is not designed in that manner due to regulations either. It is a terrible design, but lets not confuse ineptitude in landscape architecture with 'engineering'
I should add, the idea of the windiness in the above is likely to make it accessible by reducing the rate of incline/gradient to something that could be managed by someone in a wheelchair, but I don't know that.
However, even if that is the case here, the design is poorly thought out, because a shorter and more direct route (likely using stairs) should be included in the design as well. In so far as accessibility is concerned, the path would also be too narrow.
It the choice is entirely aesthetic then its really goofy. But again, nothing to do with cycling at all.
