EMP1729
If anyone has a Whalen Heat Pump in their condo unit, could you let me know the performance of such unit?
I find that in the winter, depending on the temp outside, the heat pump can only heat my unit between 16 and 22 deg C. The colder it is outside, the less it can heat inside. So if it is -5 degC, it is usually around 16 degC inside.
In the summer, it can't cool the place if the temp outside is high 20s or over 30 deg c. It usually keeps the temp around 28 deg C. I don't even bother running it in the summer (I do save on electricity though)
A HVAC technician did look at the unit and said it was fine. Is it really fine? Is this normal?
