News   Jul 30, 2024
 1.1K     4
News   Jul 30, 2024
 1.8K     4
News   Jul 30, 2024
 681     0
Toronto CityPlace: Montage + Neo (Concord Adex, 47 + 16s, KPMB)
Wow!! Just....wow.... What the square footage of that apartment?? 300?? 200? (< obvious exaggeration)
That is the smallest suite I ever saw anywhere, I am not even kidding! (NOT an exaggeration)
Holy cow. I thought my suite is small...
Does the bedroom have a window? A den?
what's in the gift basket? :D
it's 555 sq ft based on the layout that resembles unit 09 in montage LE http://cityplace.ca/montage_le/
if it's unit 09 then yes.. see pic above
That is one sad looking "suite".
Are we sure the image wasn't somehow squished to make it look so narrow? The layout diagram makes it look like you could comfortably fit a table of four in front of the stove.
PDI at Montage revealed a great, fun lobby, friendly neighbours and courteous security.
Yeah... the Montage lobby is fun. I think they used whatever spare change change was left on it, on the Neo lobby. That being said, the Neo suites seem to be for the most part a little better thought out. Give/take I suppose.
One of the things I hate about Concord Adex is the lack of room dimensions in their floorplans and the use of micro-scale furniture to make the suite look bigger.
My guess, the LR/DR/kitchen is no wider than 10ft wall-to-wall.
If you look at the image, you will notice how narrow that table is ... probably no wider than 2ft.
I went through some open houses @ Montage + Montage LE this weekend ... while I was generally satisfied with the units inside (decent but not spectacular), I was super disappointed in the common areas (hallways, elevators) ... it look so poorly composed it is comparable to a rental apartment ... low ceilings in the hallways (7' in first 30 floors, 7'6" in upper LE section), bare white walls, no enhanced trims/design around suite entrances, crappy lighting ... and further, there's only 2 small-dinky elevators that service the lower 30 floor of Montage, I couldn't believe it
after seeing the building, I would never pay to live there ~
Now I understand the various comments on Concord Adex :eek:
Are the corridors really complete? Maybe they're waiting for most occupants to move in before dressing the hallways with paint and wallpaper in order to avoid scratches and dents from furniture being moved through them?
That sounds horrible. A friend of mine lives in the older cityplace building connected to the skydome. The hallways are very basic.....all off white...kinda hospital-ish but it works...the ceillings are quite high...
The one's I've been in are the same. White hallway walls, overly bright lighting and low key suite entrances.
