A
afransen TO
Guest
biz, read the paper posted in this thread. It is "impossible" for jet fuel to melt or even sufficiently weaken the steel structural supports in order to cause the building to collapse.
The fact that he stated it would be "impossible" for the towers to have collapsed from the impact of plane impact is either neglectful or deceitful on his part. First off, on what basis can it be "impossible?" Second of all, watch the footage and note that the impact of the aircraft did not bring the buildings down. The weakening of structural steel brought about by the burning of aircraft fuel caused the buildings to collapse on themselves. So no shit, the plane impacts did not directly cause the buildings to collapse at the moment of impact, but they were the contributing factor to the eventual collapse.
as well as the overhwhelming evidence that explosives were used on Sept 11.
It's overwhelmingly obvious that the towers simply didn't collapse as you suggest due to the burning jet fuel (which burned mostly outside of the building and was finished burning within 20 minutes).
Do they not realize that in order for that to happen the steel cores of the WTC (something the 9/11 commission report completely neglected to mention) would have to be weakened?
Which means since the entire structure is steel (thus acting like the heatsink on your computer) the ENTIRE buildings would have to reach temperatures not even possible from burning jet fuel let alone have enough energy to heat the entire building.
You seem to have 'evidence' confused with 'theory'. No one has offered any direct proof that explosives were used. No video. No explosives materials. Nothing. There are however lots of 'ideas', 'guesses', and 'theories' as too the use of explosives. The two concepts are very different.
I would say there is less evidence to suggest that the buildings collapsed as a result of the jet fuel fires. You're confusing correlation and causation (ie, just because the buildings were on fire prior to their collapse does not suggest that the fire caused the collapse).
I'd be surprised if the jet fuel lasted longer than 10 minutes. However, there were a LOT more combustibles in those buildings than just jet fuel.
Not the entire steel cores, just locally at the failures.
So in order to cut a hole in the hull of a steel ship, I have to heat the entire ship to the point of melting? Pull the other leg, it's got bells on...
Explain how concrete and steel can be pulvarized to dust like and be ejected outwards?
Which certainly won't burn at a temperature to weaken even the lowest grade of steel.
I'm no expert, but the bulk of the building was made up of the steel reinfornced columns, according to FEMA in the official report the building was hollow which was it's biggest design flaw. Hmm... most of it appears to be compramised of the steel columns, fire really caused them to collapse at the same rate the floors "pancaked" downwards offering NO resisitance at all as demonstrated by the near free-fall speed of the collapse?
No, but think of how a heatsink works, the WTC was designed to act as a giant heatsink.
Both buildings are destroyed by their collapse, not by explosives. Their structures are weakened by the impact of the aircraft and the subsequent damage, heating and softening of additional steel support structures. If the "pulverizing" of the buildings was caused by explosives we would have observed the entire structures being obliterated all at once.
There is no evidence for planted explosives. None. Also, there is no evidence for a government/military/intelligence conspiracy at work. There are only accusations, questionable interpretations, unquestioned beliefs and a silent vacuum with respect to solid proof for this type of grand conspiracy. What there is, however, is a history of terrorist threats against these buildings, and video footage showing two large aircraft slamming into them at high velocity.
Structural steel tends to lose it's strength at ~500 C. A normal class A fire will burn a lot higher than that. That's why most modern steel structure have the structural elements wrapped in insulation, with a plan to put the fire out before the steel warms up too much. Unfortunately for the WTC, nobody considered all of those floors being simultaneously lit up at the same time.
How was it designed to act as a giant heat sink?
Maybe Al Qaeda planted the explosives? Discuss.
Or little green men from Mars? Or the tooth fairy? Both possibilities are as plausible as the bizarre theory presented as fact above.
If such a group of persons were able to get a few samples of steel or concrete in the building then actual, physical tests could be run to determine the properties of it. Maybe a few bodies could be exhumed as well so that they could test some of the victims for various chemicals or toxins that may be associated with a bomb.
