35- and 39-Storey Towers Proposed at Future Emery LRT Stop | UrbanToronto
Designed by Icon Architects for Pinemount Developments and Elysium Investments, 3434 Weston Road would feature 35- and 39-storey towers, with 832 residential units and retail at grade. The site is south of Finch Avenue and the future Emery LRT station.urbantoronto.ca
How does that work? Use the York sub to get from the Newmarket Sub to the MacTier Sub? You'd still be able to get stations at Woodbridge (probably a couple) and Kleinberg.I agree, however it seems that the current plan for Caledon/Bolton GO is to divert over to the Newmarket Sub. Their rationale being that the Weston Sub is congested with the UPX, Kitchener, and Milton lines.
I believe this is short sighted as the NW corner of the city is pretty poorly served by transit. Eglinton, and Finch LRT's (moreso Finch) are significant upgrades to the area. However I believe the area still needs a connection to the DT and a GO line
This is not the proposed alignment right now, obviously that could change but right now it will be using the Weston Sub to get to its proposed terminus station.seems that the current plan for Caledon/Bolton GO is to divert over to the Newmarket Sub. Their rationale being that the Weston Sub is congested with the UPX, Kitchener, and Milton lines
What’s the basis for this - something Metrolinx says, or something Caledon is pushing? There isn’t a clear path for a new route other than Bolton across country to south of King City GO, and bridgework and power lines at the crossing of York and McTier make constructing a curve a tricky proposition.I agree, however it seems that the current plan for Caledon/Bolton GO is to divert over to the Newmarket Sub.
They made a typo where the second "Go" should have been "GO".
When did that change?This is not the proposed alignment right now, obviously that could change but right now it will be using the Weston Sub to get to its proposed terminus station.
Is the Caledon-Vaughan GO Line part of Doug Ford's GO 2.0 Plan?
DIRECTION
Our plan for the generational GO 2.0 project will require substantial cooperation from a variety of partners, including the federal government, which has already indicated its support. Pursuant to authority under the above-noted legislative provision, Metrolinx is hereby directed to:
2 c. Opportunities for new GO lines, stations, and Transit-Oriented Communities, including benefits from increased connections to local transit" so interpret that as you will.
When I looked at york regions plan to me it implied this stuff is going to be 30+ years outIs the Caledon-Vaughan GO Line part of Doug Ford's GO 2.0 Plan?
I mean it will even if they dont intend to, at the pace things are goingWhen I looked at york regions plan to me it implied this stuff is going to be 30+ years out
Part of the reason we ‘forecast’ things like this nowadays is because it requires significant time and capital that we do not have- because it’s being spent on other projects.I mean it will even if they dont intend to, at the pace things are going
Doesn't Brampton transit now serve Bolton? Not very well but it's something...Peak-only services don’t make sense post COVID. Friendly reminder Caledon is also set to grow from 80k today to 350k by 2051. Let’s give them good transit now to help them maybe grow sustainably.
