kEiThZ
3) One of the biggest noise complaints were during engine run ups in the mornings. It is my understanding that engine run ups are required for prop engines but not jet engines? That removes a significant amount of noise creation
The run-ups are required if maintenance is performed. I'm guessing Porter does their maintenance at night when the airport isn't operating and usually likes to run them up in the morning to return them to maintenance if the run-up fails.
Run-ups will probably be required on the CSeries. The frequency of them though, I can't say. Would have to see the manuals.
4) With Porter using almost all available slots at YTZ the only way to grow is to increase the capacity of the aircraft leaving YTZ per slot. Q400's seat about 80 (around 70 in Porter's configuration), the C-Series seats about 110 in it's roomiest configuration. Therefore Porter can get passenger growth of somewhere between 37-57% per slot just by moving to the C-Series.
At the moment with a load factor around 61%, Porter isn't actually all that concerned about growth. This will be an eventual concern to be sure. Just not right now.
Porter is, however, flying a lot more than they need to. They are doing this to keep the slots out of Air Canada's hands. If they get the CSeries, they will reduce service to Ottawa and Montreal and use those slots to service higher-yielding longer haul destinations.
So at least initially, this actually means that you wont see that many jets taking off from YTZ. With the time difference, for example, a CSeries aircaft would only be able to fit in one return run to LA or Vancouver or may be two return runs to Miami. Of course, as Porter's flights to Ottawa and Montreal then start filling up, they'll replace the Q400 with the CS100. That's why they are only buying 12 now, but taking up 18 options. Those options would be to replace their Q400 fleet down the road.
