News   Dec 12, 2025
 598     0
News   Dec 12, 2025
 1.4K     6
News   Dec 12, 2025
 694     0
407 Rail Freight Bypass/The Missing Link
After reading this release, I'm concerned about what this means for the Kitchener line, among other projects. It seems we're in a constant state of, "yes, no, maybe so" because we have Metrolinx either getting projects closer to completion, shelving projects for whatever reason, committing to projects, but taking years to ever get shovels in the ground, and as a consequence, the projects taking much longer due to inflation, among other systemic issues that have plagued Metrolinx for years, if not decades.
It feels like nobody is learning that the more we push projects further down the road, the more things cost, the more resources that are involved, the more Metrolinx, their subsidiaries, and other stakeholders have to delegate and make changes because of other construction projects that ended up receiving approval, or being constructed while transit projects were shelved. It's a recipe for disaster if Metrolinx is not out in the community actually doing research on what is happening, and is instead steamrolling other projects just because they're a government agency and suddenly have a sense of urgency for a few weeks.
An example of this is downtown Brampton along Railroad Street. I can't find the document right now, but there's a proposed project for three highrises that was supposed to be starting sometime within the next year or two. Due to the need for an additional track or two along that exact corridor, along with the proper buffer, the new proposal is to instead change the orientation of the highrises, and instead of constructing three, they construct two.
That being said, I have no idea what the future holds, or if this missing link will even be constructed. I don't see any business use case that will make CN/CPKC want to use anything that Ford/Metrolinx will propose if it takes them so far out of the way and as a result extends their fuel, crew time, and so on. I can understand that CN was at one point a crown corp, and Ford/Metrolinx may want to use that as leverage, but 1995 was 30 years ago.
I agree. This is such a weird time to go all in on this concept when you've just about done or committed to do everything to avoid needing to do it.
This all but confirms to me that he wants an election, but when to do it will be tricky.
The idea of running CPKC and CN in the existing ROW along the 407 is out of the question as it cannot support 4 tracks nor 6 tracks
Can I ask you to clarify? Do you mean the 407 hydro corridor can't support 4 tracks, or that the 407 highway corridor can't support 4 tracks? Or that neither one could support even 2 tracks, which would be 4 total between them?
I guess what I'm also asking is what makes the hydro corridor north of Finch better than the hydro corridor along the 407? Is it that much straighter or are the gradients easier to deal with? These aren't rhetorical questions. I'm genuinely asking.
I also wonder if the 401 traffic might be better relieved by a Sheppard subway extension, since Sheppard is closer to the 401 than the Finch hydro corridor, and a subway would stop more than a conventional GO line (though I suppose a finch hydro transit corridor might not be conventional GO either).
I share the concern that ML may be walking the plan back.... or at least using the GO 2.0 as an excuse to rest on their oars.
A key is, the public stakeholders (ie we observers, plus the public and municipal officials in affected communities) needs to know what firm commitment ML has with CN re upgrading the Bramalea-Silver section.... and what limits does it contain for the service plan (ie how many trains will CN allow when it is complete)..... and is the funding committed and released?
I can sort of (gritting my teeth) understand that ML has not rushed to finish construction west of Silver, given that the upgrading of the CN owned segment may be critical path, and so the remaining elements are not affecting service offerings.. (I'm being charitable, sure seems more likely that ML simply hasn't managed this work properly). But it's really needed to know the plan going forward from today, and are promises being kept.
A challenge for CPKC is that while it runs fewer trains than previously on the Milton line, there are few places where those longer trains can stop without blocking level crossings. So unlike past years, every freight now needs a "clear alley" through the length of the route. Plus, stopping a longer freight is operationally less desirable - a trickier proposition for the operator. While the line may look underused, that trackage is needed to keep traffic moving.
Judicious grade separation might help, but CP is unlikely to give up its two dedicated freight tracks.
There are 4 crossings in Streetsville where 2 will remain grade crossing as well 2 grade crossing west of Dixie with the rest to be grade separation. Been a long time I seen a train stop on line in Mississauga. Seen them more on line stop in Toronto where it doesn't effect GO. CPKC seems to split the number of trains equal for day and night.
It will cost close to $200 million to deal with grade crossing in Mississauga with Mississauga Rd being the most expansive one of them.
Its Hwy 407 as well the hydro corridor considering hydro doesn't want train/transit in the corridor these days.,
The 401 will not be better off with a Sheppard or a 401 elevated subway if they were built. One only has to look where traffic is getting on/off the 401 to see it. You have the 427/400/404 as the main points. Eastbound 401 traffic are using 427/400 higher that the 404 with 400 going west on 401 and south on 427
Putting it on the CPKC line, however, simply replicates the TTC Line 2, and is not far enough north to attract riders from 401 and beyond..
If the Midtown line were to start in Milton and end in Pickering then I think that would attract some 401 drivers.
There is more than enough capacity today and tomorrow for the Milton Line with out GO using any tracks tacks at all, let alone one a peak time.. Adding 2 more tracks will deal with GO service needs even with a fly under/over at the Humber.
The number of CPKC trains on the Milton Line is almost 50% less than in the past as the trains are 2-4 times longer today that requires less trains. Its possible from time to time CPKC could use a 3rd track, but rarely it will happen. What ML will want from the 4 track corridor is able to run express trains on a 3rd track. Electrify the line is an issues and by the time the corridor is 4 track, battery power or other type of power will replace the need for the line to be electrified.
Keep in min, CPKC will be using that line on a daily base to service the Streetsville yard and various industries along it regardless if ML owns that corridor. Not all movements can take place at night.
The last cost to 4 track the corridor was $2,5B and take 3 years to do it.
Yeah, 4 tracks would be enough, but you didn't address my original point which is about "ownership".
Plus you bring up another point I forgot. Not building the freight bypasses and sharing the line with CPKC will make electrification more difficult.
You sure about that?
Excellent! People kept telling me that the proposed flyover at Georgetown would make the 407 freight bypass obsolete, but I never believed it. Even with the flyover, the freight bypass would eventually still be needed.
I can't see CN agreeing to go ahead with the 407 freight bypass if it means having to share the track with CPKC. Allowing CPKC trains to run on the Halton & York subdivisions would have a negative impact on CN operations at the Brampton Intermodal facility and the MAC yard. I don't even think they'll agree to GO trains running on this subdivision. Which is okay IMO. Just taking CN trains off the Kitchener line would be a huge boost to the passenger rail network in the GTA.
They would probably be more likely to agree to having GO run on the subdivision than have CPKC... GO has run on detours before...
plus the grade required to get from the Halton to Mactier sub would be 2-3% which would be way too much for a freight train...
If CN were to construct 407 bypass, then they'll have a much better mainline setup in Toronto compared to CPKC. It'll effectively be a straight east-west line across North Toronto with easy access to their Intermodal facility in Brampton and freight yard in Vaughan.
Would be about 4-5 miles shorter than the existing Halton sub through Silver which we usually run trains at 35 - 50 mph on the halton sub which means it would be about 7-12 minutes faster for CN.
That's good for local traffic but it would be too many stops to get from Pickering to Brampton
The idea of running CPKC and CN in the existing ROW along the 407 is out of the question as it cannot support 4 tracks nor 6 tracks for the GO 407 plan service which is currently plan as BRT that can be upgraded to LRT if and when it every gets built.
As for the idea of CPKC using the 413, cannot see it as it adds too much traveling time compared to the current route. I said in early 2000's that all rail corridors needs to be 4 track and easy to be done if funding is in place. The Milton Line is partly 3rd track today with most all new bridges in place built for 4 tracks along with most existing bridges on the line.
Using the 413 doesn’t do enough to alleviate things, as presumably you would want a solution for the entire mainline thru the GTA, not just for the western half, at the cost of a 413 rail line.
But more importantly…
Is the 407’s right of way really that small that they couldn’t fit 4-6 tracks? I’ve long thought that could be our silver bullet; 2 tracks for CP, 2 tracks for CN (where applicable) and 2 tracks for Metrolinx, mode pending. A huge, multipurpose mainline that could be built on existing public land.
Obviously the transit right of way as planned is only intended for two bus lanes/tracks, but the amount of clear land paralleling the 407 is insane. Some of this is the hydro corridor, sure- but any rail along the 407 ROW is far from a tight fit… no? It looks like it’s 160m wide. I don’t really know how much we can tweak the transitway design for this, but I would imagine the space exists if we bite the bullet on reconfiguring things more significantly instead.
I have lost sight of exactly where the pylons run. But I do recall the Davis Government's plan to run a ITCS system along it. The routing made a lot of sense, even if it was beyond the technology of that day and a bit fanciful as to cost.
It may be Hydro doctrine not to run transit in a Hydro corridor, but if today's government is actually looking for solutions, I would give it a look.
Cost is always relative. It's a continuous right of way that doesn't impinge on CN or neighbouring landowners, roughly the right distance north of the 401 and south of Markham/Vaughan. If I were drawing a line on the map, it is in about the right place..
Doesn't need to be 12-car bilevels - if ML intends to procure a different train mode, this might be compatible.
Sorry, when I was thinking GO in the Hydro corridor, I was thinking heavy rail GO as we currently know it.
I'm not smart enough to know the interplay between electric rail running in close proximity to six 230Kv circuits. I would imagine linear induction, which was the 'tech du jour' back then, would have been 'interesting'.
I grew up in a house that backed on to the corridor; over our backyard fence was the corridor. The ROW varies in width, but at that stretch, the distance between the private property boundaries and the nearest circuit is about 12-15 metres; in a couple of spots it is around five.
My main pushback against those citing the varied origins and destinations of the 401’s drivers is that a crosstown rail service would work the same way. There are 7 GO Lines and 2-3 subways that cross the 401’s vicinity, and more are on the way. While we may not have every major highway o/d pair covered, we do have enough to work with.
Generally, I do think you are undershooting how much ridership can be generated by a crosstown service. I appreciate your hard realism, and your commentary is always technical and informed. But, respectfully, no such line could only justify peak service as you claimed. And certainly not so when they’d be done. Perhaps your right if examined in isolation, but not as a part of the network.
Constructing the 407 freight bypass and allowing more frequent and better service on the Kitchener line would do a lot to take cars off the 401.
I would like to think that once the other lines get up to the same service levels as the Lakeshore line, then Union station will be used more as a transfer point to get from one side of the GTA to the other.
I'm certain there's a lot of people who live west of Toronto who ride the Kitchener, Milton, LSW lines into Union, and then transfer onto the Lakeshore East to go into Durham.
I’m not denying that it would take drivers off- rather, that almost any number of deferred drivers is small fry for transit ridership figures— which is why it shouldn’t be used as a be-all-end-all measure.
If you use only a highway as a reference point (or auto traffic in general) transit seems like overkill, because it’s just that much more efficient. Really, you need to make sure the transit line has a purpose within the transit network as well as offsetting autos/highways, because that’s where major ridership can really come in.
