G
ganjavih
Guest
The temperature today was two degrees cooler than the same time last year! It's proven! Global warming is a fraud!
If CO2 helps the atmosphere get warmer, in turn raising ocean temperature, the storms can gain more heat energy from the water. You're right that the energy source is the sun, and as that energy gets trapped on earth instead of bouncing back into space, things are going to heat up.
The sun is a massive source of energy, and therefore raises the temperature of the oceans during the day. When the sun has set, that energy is released, which is why it gets colder at night. The rate that heat is gained or lost is proportional to the difference in temperature between the two bodies. In the fall when the water temperature might be 10 degrees, it loses heat much more rapidly at night when the air temperature is -20 than when it's +5.In short, yes C02 does help the atmosphere stay warm, but oceans are warmed by the sun and far better at holding their temperature than air due to density differences.
