News   Apr 13, 2026
 414     0
News   Apr 13, 2026
 1.5K     3
News   Apr 13, 2026
 593     0
Why should two passenger rail services provide overlapping services in the same area, still using third party rail (or should VIA run on GO trackage)? Should VIA provide Toronto-area commuter service? Should GO provide inter-city service to Ottawa? Makes little sense to me.
For those of you who think I'm nuts for stating hydrogen is the future for non-catenary VIA...............................CP has just announced, www.H2-view.com , that they have contracted ATCO to build 2 hydrogen refueling centres in Alberta. They will be in Cal/Edm and will be green hydrogen using electrolysis and will produce, store, and fuel their expanding hydrogen freight locomotive vehicles. The facilities will be constructed quite quickly and will be operational by 2023.
This is an example of what I have often stated. The freight companies will be building their hydrogen infrastructure and VIA and other passenger rail services will be able to make use of it. If VIA ever decides to return service from Cal/Edm, this would be an ideal place to begin testing their hydrogen abilities. A private company wants to build a train service from Calgary International to Banff via downtown and again this would be vastly simplified by being able to use freight company hydrogen infrastructure as opposed to building their own.
Transforming diesel locos into hydrogen ones is MUCH cheaper and faster than rebuilding the units for catenary and/or diesel or buying new hydrogen EMUs.
It’s complicated, I agree… but even if it’s hard to create a bright line, and even if the two do overlap in spots, I do believe there are two or three different system and service roles that have totally different business models and funding bases and clientelles and governance needs.
It’s possible that a single Oncorr type operator could run them all (Amtrak has won commuter operation contracts, for instance, as well as 403b services, as well as federally mandated services) …. but ultimately it is hard for one organization to ride that many different types of ponies simultaneously.
I would be horrified if Ottawa volunteered to run GO, because the responsiveness to local interests would be sacrificed and “national” agendas would inevitably creep in. And VIA lacks a legal mandate to fend off the federal bureaucracy..
Conversely I suppose GO could absorb longer distance runs, but these demand different amenities and infrastructure and equipment. Funding models would be completely different. Inevitably, the operating organization would be set up with siloes suited to each type of business… and for many purposes it would be three organizations under one roof. There’s wisdom in having a single infrastructure for integrated Ontario-Quebec intercity service, all the way to Detroit.
In Japan they have trains that are 6 car express trains, 2 cars have reserved seating and the rest have regular seats. The objective is to allow transit to be more competitive. Why have overlapping services?
If I live in Hamilton and need to go to Oshawa for a meeting, driving THROUGH Toronto is such a pain, but if the train could get me there faster and ran at all times during the day it would make it more attractive. Currently it takes double the amount of time to take transit than to drive, if you could make this comparable to driving, more people would take transit.
VS
I cringe at arguments of the form “In (country) they have (nice thing)” because a) their having something doesn’t make it a solution to our problem and b) we may not have the ability to apply that something here without impacting a lot of other things.
I have no argument with the concept of express trains, but deciding which nodes to serve is a lot more complicated than your simplistic example. Even with its ambitious and high-cost expansion program, ML has only so much track available. They may be receptive to express opportunities but it may be impossible to ever fit them onto their network.
In the case of regional centres at the periphery of the GTA, such as Niagara, Kitchener, and Cobourg/Belleville - it makes no sense to run stopping trains. Those stops will mostly inconvenience any significant ridership component making an end to end trip. A regional service that serves the most distant stops and then runs express alongside a central stopping commuter service is better. But some judicious stopping will create more utility and more travel opportunities than a pure express. It’s a balancing act.
The worst case would be to have two different agencies with different masters and different business models trying to dovetail a service plan on top of each other. Which is why I have concluded that GO should run both into the GTA. There is no easy dividing line - a regional service running east of Bowmanville is a good example, it could remain a VIA line because the “region” stretches all the way to Kingston and there are only a few stops along the way (as yet). But if Ontario’s MTO concluded that the 401 is just getting too busy along that stretch - one would want VIA/Ottawa to be responsive to the problem. It might be simpler for GO to tackle that and have VIA bow out.
Because overlapping services can have different stopping patterns and thus different speeds. Japanese mainlines have tons of different stopping patterns too. Even the Tokaido Shinkansen has three stopping patterns: Kodama (local), Hikari (express) and Nozomi (super express). And the Nozomi also has different ticket conditions, so certain passes are not accepted whereas they may be on Kodama or Hikari trains.
Sure, GO could theoretically be set up to enable different types of tickets (reserved/unreserved seats, first/second class, etc), but there's not really much point in doing so, since VIA already offers the alternatives that GO doesn't, and there is plenty of other difference between VIA and GO offerings to justify overlapping along a corridor. Namely that VIA trains make far fewer stops, require tickets booked for a specific train (because they're lower-capacity trains than GO) and continue outside of GO's service area.
GO's planned all-day Regional Express services to destinations such as Kitchener, Niagara Falls, Hamilton and Barrie certainly have the potential to infringe on VIA's market, but I think that there is plenty of room for VIA to move upmarket to avoid redundancy. For example, VIA trains to Kitchener currently take about the same time as GO express trains, but ticket prices are much higher. If VIA were able to drop some intermediate stops and offer shorter travel times than GO, their product could be positioned as a premium-express alternative to GO's fairly basic Regional Express services.
Yes, and once GO starts operating all-day express trains from Toronto to Hamilton, it won't take as long to cross the region on transit. Ideally the Hamilton express would continue through to Oshawa, but that may be somewhat limited by the discrepancy in track capacity west and east of Union.
Lakeshore West will have 4 tracks, while Lakeshore East will only have 2.
Kitchener will have 4 tracks while Stouffville will only have 2.
Barrie will have 2 tracks, while Richmond Hill will only have 1.
Because different services have different stopping patterns and thus different speeds. Japanese mainlines have tons of different stopping patterns too. Even the Tokaido Shinkansen has three stopping patterns: Kodama (local), Hikari (express) and Nozomi (super express). And the Nozomi also has different ticket conditions, so certain passes are not accepted whereas they may be on Kodama or Hikari trains.
Sure, GO could theoretically be set up to enable different types of tickets (reserved/unreserved seats, first/second class, etc), but there's not really much point in doing so, since VIA already offers the alternatives that GO doesn't, and there is plenty of difference between service types to justify overlapping VIA and GO services. Namely that VIA trains make far fewer stops, require tickets booked for a specific train (because they're lower-capacity trains than GO) and continue outside of GO's service area.
Yes, and once GO starts operating all-day express trains from Toronto to Hamilton, Kitchener and Barrie it won't take as long to cross the region on transit. Ideally the Hamilton express would continue through to Oshawa, but that may be somewhat limited by the discrepancy in track capacity west and east of Union.
Lakeshore east has space for an additional track.
The corridor east of Union is being widened to 4 mainline tracks, to be used by both the Stouffville and Lakeshore East lines as well as VIA trains. According to Verster's comments about cancelling the rail-to-rail grade separation at Scarborough Junction, 2 will be for Stouffville and 2 will be for Lakeshore East.
You should see the QEW in the morning coming into Toronto, its Bumper to Bumper from Burlington to Southdown and then again from before the QEW bridge until the 427. Brutal.
This is why VIA should be in the commuter service offering express from Burlington/Aldershot to Toronto and then to Oshawa.
This again raises the question of what is the problem you are trying to fix. If you want to relief highway congestion, then operating 3-6 car trains with a capacity of less than 70 seats per coach would be like throwing popcorn at a car...
Not to mention that this neither falls into the mandate of VIA or the federal government (why should taxpayers in Nova Scotia, Nunavut or BC pay for the operating deficit of commuter rail operations in the GTHA?) nor does VIA have access to any spare and suitable rolling stock for such mass transit applications...
This again raises the question of what is the problem you are trying to fix. If you want to relief highway congestion, then operating 3-6 car trains with a capacity of less than 70 seats each is like throwing popcorn at a car...
I previously mentioned that it doesn't matter who provides the service. Simply that it should exist.
You can run 12 car express trains but I don't know if there would be that much demand. If you could run it from Niagara to Oshawa that would be better but they don't own the trackage.
This is surely an important question, but I suspect that this is not the most appropriate thread to discuss it...
Except that it does matter who provides the service, because somebody has to subsidize it.
I get the a user/commuter may not care who offers it. But it's relevant for VIA. Let's say there was no extra funding coming, it would mean that VIA would have to cut elsewhere to offer this service.
They may not care whether their train is yellow or green, but they will certainly care whether they are going to pay the ticket prices which are customary on the green trains or on the yellow trains. Even more so, if they also use other transit agencies and would therefore benefit from fare integration which is unlikely to include VIA in the foreseeable future…
There are lots of examples of Amtrak providing commuter service in the US. How does that get funded?
In the US, Congress has passed legislation giving Amtrak a mandate to run state funded services. There are many precedents on how the services are equipped, costing, etc. See here.
In Canada, VIA does not have the same legal authority. Governments of all stripes have refused to pass enabling legislation for VIA. In part, this is because they fear that the provinces might actually access the legislation, and VIA might have a continuing raison d’être.. Much more convenient if VIA can be cancelled at any time.
