News   Apr 10, 2026
 152     0
News   Apr 10, 2026
 266     0
News   Apr 09, 2026
 8.9K     1
So it is primarily the rail corridors in western Canada that have single track that are nearing capacity when only considering freight traffic? Would that still be true for Toronto-Montreal if CN and CP were to share one, double tracked corridor, or would that combination push them over the edge?
The issue in the corridor wouldn't be capacity exactly, but coordination, and not having preferred timeslots, and not having best access to associated facilities, without interfering with the line. Certainly having unencumbered operational control and plenty of ROW capacity for future expansion is viewed as an asset by both companies. They use it to provide premium services, like guaranteed delivery timelines and some just in time services (though limited).
Plus having more trains onto the same corridor will raise pressures to add grade separations. Which might cost more than just adding another corridor!
How is coordinating time slots for railway trains any more onerous than, say, Westjet and Air Canada coordinating runway and gate allocations for competing flights between YYZ and YUL?
Assuming good connections at either end, what "Associated Facilities" exist between Oshawa and Dorval beyond yards at Belleville, Smiths Falls, and Coteau?
How does having a single rail traffic control center encumber operational control on a jointly used line?
If VIA is unable to leverage existing grade separation, it will be limited to a 110 mph crossing speed limit regardless of where it runs. This impacts any supposition of a later "Phase II" upgrade to HFR.
I would be interested in what your map looks like with farmers' crossings and minor concession road crossings deleted.
This is especially problematic on CP's Belleville Sub through Belleville.
It would be certainly be interesting to compare the cost and urgency of grade separations to resolve a different Belleville routing with the cost and urgency of grade separations on major north-south roads in the Durham-Northumberland region which cross the proposed HFR route. Also crossings through Perth where HFR will transit. Vehicle volumes on all of these are substantial, and the potential risks associated with hourly high speed trains in each direction, versus current or future volume of freight trains, are a consideration.
And then, how does the cost and scope of a program of further grade separation on the CP/CN lines compare with the cost of rebuilding a new line for VIA?
At an airport, a Cessna and a Dreamliner both have the same slot. Therefore, upgrading the airport is not needed if it cans support a larger plane. Oncoming trains must sit in sidings as you pass. There are only so many siding and are only so long. A train that is longer than the siding is said to be an "over siding train". These trains are used by both CN and CP to maximize profits. They save money because the longer train still only needs 2 people operating it.
So, using the airport example. You have a few options to get more traffic:
1) Extend the length of existing sidings.
2) Put in more sidings
3) Double track
3) Double track
Or put in legislation that prevents railways from running trains that are longer than sidings. Or trains that are really long and impede VIA trains.
I was talking about what the company can do, not what the government can do. I would love it if the wording was as simple that a train cannot leave a terminal if between it and the next terminal, a siding is not long enough to fit it.
Nobody knows for sure in which alternative reality Micheal lives, but in the reality the rest of us are part of and where individuals and organizations adapt their behaviors to the incentives they are given, what happens if the shortest siding defines the maximum allowable train length in your network? Some short sidings may be extended, but most short sidings (which are still way longer than even the full-sized Canadian) would just get removed - to the detriment of the very passenger trains you want to boost (because unlike with many freight trains, they still fitted even the longest passenger trains).
Short-sighted and counter-productive incentive-setting at its finest!
Because there simply isn't an equivalent to timetable slots for a transport mode which has an almost infinite amount of possible paths (resulting from horizontal and vertical variations of any thinkable path) between any two airports to choose from, very unlike a mode which, well, is bound to a physical guideway?
Judging by the RAC's interactive railway map:
  • CN Kingston Subdivision (from west to east)
    • Yards in Kingston, Brockville
    • Freight customers or loading facilities at MP 30 (Les Cedres), MP 35 (Coteau-du-Lac), MP 38 (Coteau Junction with Valleyfield Sub), MP 65/66 (Cornwall), MP 90/92 (Morrisburg), MP 105 (Cardinal), MP 112/114 (Prescott), MP 118/119/121 (Maitland), MP 126 (Brockville), MP 174/178 (Kingston), MP 187 (Bombardier), MP 188 (Ernestown), MP 190 (McIntyre), MP 220 (Belleville), MP 233 (Trenton), MP 264 (Cobourg), MP 271 (Port Hope), MP 292 (west of Bowmansville) and at MP 300 (east of Oshawa)
  • CP Vaudreuil/Winchester/Belleville Subdivisions (from west to east)
    • Vaudreuil Subdivision
      • A yard in Vaudreuil-Dorion
      • A freight customer at MP 13 (east of Baie-d'Urfé)
    • Winchester Subdivision
      • A yard in Bedell
      • Freight customers or loading facilities at MP 35 (east of De Beaujeu), MP 49 (west of Green Valley), MP 58 (west of Apple Hill), MP 88 (east of Winchester)
    • Belleville Subdivision
      • Freight customers or loading facilities at MP 16 (Glen Tay), MP 103 (Trenton), MP 120 (Colborne), MP 133 (East of Cobourg) and MP 175 (Oshawa)
Because you now have three control centers (CN, CP and joint) which have to coordinate movements with each other...
None of the rail corridors between Toronto and Montreal has a sufficiently long grade separated segment which would allow operation beyond 110 mph. Given that (unlike the HFR route) almost no part of the Kingston Subdivision is slated for later use as an HSR corridor, there is no economic case to grade separate it (at least not at taxpayer expense)...
Go to the RAC map and visit all road crossings marked there, while noting down those which don't fall under the two categories you just mentioned before mapping them out with the mapping software of your choice!
Nobody stops you from finally outlining which route you would use for HFR, where you would route the non-local freights of CN and CP and how you would maintain service to the existing customers along the CN and CP routes...
Given that the tightest of the various curves in Perth has a radius of only 550 meters, it is rather unlikely that trains will be able to exceed 60 mph while traversing Perth, which is not exactly what I would call "high speed trains"...
Given that grade separating the CP or CN lines and rebuilding a new line for VIA achieve wildly different things, the difference in capital requirements (if we assume there is one!) might not be as instructive as you hope...
Are there plans to restore more corridor services in the near future?
The plan is (and has always been since the beginning of the Covid-19-related service suspensions on March 17) to restore services as soon as the situation permits.
Beyond CoVid, the limited size of the Corridor fleet and challenges with the host railroads make it challenging to increase frequencies before the new fleet and HFR arrive...
With rumors' that southern Ontario will go into lockdown, I strongly suspect we will see service cuts within the next week. The question is if the cuts will come before or after Christmas?
Has the reduced service during COVID helped extend the life of some of VIA's equipment (the Renaissance cars specifically) to help better bridge the gap until the new fleet arrives? I gather there were going to be issues with equipment needing to be retired before it could be replaced.
Unless a provincial government demands asks VIA to reduce/interrupt its service, I would assume that the current schedule survives into the new year. In fact, weekend-only frequencies 46, 55, 65 and 66 will exceptionally operate on December 22/23/24 and January 2, in addition to their normal operating days of Mondays, Fridays and Sundays..
Refer to my previous post for VIA’s current schedules and note that the Canadian partially resumed service (west of Winnipeg, once per week) on December 11, just as it was announced back in October...
Unless a provincial government demands VIA to reduce/interrupt its service, I would assume that the current schedule survives into the new year..
It wouldn't be surprised if Ford requested it (not sure he has the authority to demand it). I also wouldn't be surprised if he orders all provincial highways closed for non-essential travel to discourage people from going to places that aren't under lockdown for a vacation.
Air is not infinite, flights adhere to corridors and levels, with options for delaying takeoff and/or holding in the air to match landing capacity. You understate the concern that one airline might have about its flight getting delayed at gate, while its competitor’s same-timed flight gets sent on its way.
While airlines may grumble, (and work from different terminals) nobody suggests total separation of all their operations or support functions - or airspace. And their system of slot allocation is structured to not allow any one airline to achieve an unjust advantage.
The freight railways paint this as some cruel unworkable intrusion that abuses their shareholders. Their protests are overstated by miles.
That’s the answer I was expecting: local customers, small service yards, and a few key classification points. Nothing that can't coexist with HFR. If CN swapped blocks in Smiths Falls instead of Belleville, is this rocket science?
Belleville is an interesting case study. Independent of HFR, it makes a lot of sense to divert CP along the CN alignment through town. CN would bristle, or look for a windfall. There would be a capital cost, and it would rightfully fall in part to the taxpayer. But it would be money well spent to that town’s growth and quality of life.
Taken nationally, a dozen or more diversion proposals exist, some more practical than others, often involving railways sharing each others' corridors (Winnipeg, London, Regina, Saskatoon, North Toronto......) The railways have a valid concern about how much of their expertise and managerial focus can be diverted towards such projects when their core job is to run a railway as it is. This is not a good reason to resist all of them, however. It's a question of how much can be handled at a time, and how much public money is available, and how much each railway ought to contribute... and not allowing the railways' desire to compete with each other to outweigh the public benefit of making better joint use of their corridors.
As they do now, located at different ends of the country. Plus Metrolinx, AMT, and others. One hears stories about how the interface may not be effective at the moment, but that does not mean they are being managed at their full performance potential.
I continue to ask, if CN and VIA have agreements that will enable HFR east of Coteau, what stands in the way of reaching solutions that could be applied west of there, given assurance that VIA will absorb capital investment?
Almost all grade separations are taxpayer-funded.
What triggers my periodic urge to rehash things I know we have debated before - is some posters' suggestion on the one hand that the Havelock route is the best candidate for being cheaply and easily upgraded to HSR.... yet when other routes are suggested, the response is that the terrain is too difficult, land costs are too high, etc. This argument has to cut both ways.
I accept that the Havelock line can be upgraded to the level promised by VIA for the price they have estimated.... but the total cost of that, and then raising it to HSR later, will be in the same ballpark as building a new line anywhere else.
I'm not aware (but eager to be corrected) that the HFR route through Havelock has been favoured in studies as the preferred HSR route. It's very possible that the Havelock segment of the HFR route will cease to be used should HSR emerge (unlike east of Smiths Falls, certainly).
So the question is, can the same money achieve the same performance as HFR Phase I if invested in a different route west of Smiths Falls, in a way that retains its value through into HSR.
VIA's 2008 capital plan offered an end service pattern not that far below HFR's proposal. It failed, not because it was a bad plan but because the money allocated was spent badly. The overage was only part of a $400M envelope - enough of an embarassment that the government quite reasonably refused to keep spending at the time. However, if there is more commitment (and maybe legal clout) to manage differently.... the HFR expenditure (easily $1B or more for the Havelock segment) would close the gap on the 2008 service plan - and more. This would approach VIA's desire for Toronto-Ottawa, with a better emphasis on the HFR-era Toronto-Montreal service.
Sustained or improved use of the CN line by VIA might force a displacement of some CN through freight, but it need not remove it entirely. I can't imagine that the amount shifted would choke the CP line, especially if it received some investment also. Many double track railroads in North America commonly accommodate 60-80 trains a day. A single track line with good passing capability (which is exactly how the Winchester Sub is configured) has been said to be capable of 70% of that capacity. Do we expect the combined CN-CP throughput between Toronto and Montreal to reach even 42 freight trains a day within 25 years?
Any grade separation along the CN and CP lines (which will remain under every scenario) is money well spent. Any money spent on grade separation on the Havelock line has long term value only if HSR goes there. Are we really ready to nail that down? @Darwinkgo suggests that pressure for grade separation will follow freight volume, but I would expect it would follow the combination of population and HFR frequency given there will be more passenger trains out there than freight.
I am pessimistic that HSR will be achieved, or the Havelock line upgraded, within 30-40 years. That's a long time to live with the deficiencies of that routing.
I can accept VIA's need to present the most positive case for HFR, and I realise that in political space it's often habit to make things sound like more of a silver bullet than they are. In real life, every proposal will have pro's and con's.
The Havelock line may be all that's affordable, and all that's sellable, but....it has a definite limit on its upper end. When people ask, "is this the best plan", I can answer "it's the only plan that's workable for the money and appetite available".... but one should not undersell the tradeoff's being made. Nor should one undersell what could be achieved if a shift to coproduction were in the picture.
At worst case, I may be suggesting an expense of a further $1-2B, but the value obtained would be worth it.
