News   Apr 02, 2026
 2.1K     2
News   Apr 02, 2026
 1K     0
News   Apr 02, 2026
 2.5K     2
Seems like via has added an HEP2 set back to the QC-MTL-OTW during the venture reconfiguration changes. I’m currently on train 33 and it is made up of 5 HEP2 cars and double ended engines. They even reversed the train direction in Montreal like with the ventures instead of backing out to the bridge as they used to do with double ended LRCs so this seems to be a new official practice.
Looking at https://www.traincar.info/ it seems like this is a planned change and that train 31 now uses 4 car ventures, with only one business car removed.
Also mildly interesting, there was a land acknowledgement in the departure announcements.
Shortening one consist to make another one longer is kinda pointless unless you are going to J the short ones together.
Also, there was a land acknowledgement in the departure announcements. Not sure if I just didn’t notice it before or if it’s a new practice.
Thats honestly cringe... all this charades for no reason. This does nothing for indigenous rights.
Its like singing the national anthem in grade school.
It’s like singing the national anthem in grade school.
I only noticed it the second announcement it seemed particularly uninspired. I may be recalling wrong but I think it was just “VIA Rail recognizes the traditional territories its trains operate in.” Not as lame as the Victorian railways prerecorded land acknowledgements but IMO if something is worth doing it’s worth doing well.
I’m surprised it’s just one car removed, I thought it would be at two to make a 7 car venture as discussed prior. This train doesn’t seem like the worst to shorten as I believe it only cycles Montreal-Ottawa once a day as the first train out of Montreal and last from Ottawa. Would be nice if it was a later departure from Ottawa though, could make a 3 car train make more sense assuming there is still another 6pm departure. Train 38 was busy leaving at 6pm when I last used it.
Edit:
Trains 31/38 are likely standard 5 car venture sets with one business class car unused.
Everywhere is doing it as thy think it is meaningful, and part of the Truth and Reconciliation. Honestly,I take it as no different that they do they announcements in both languages.
Reactions: PL1
I just learned that the HEP2 set from train 33 turns into train 47 and continues to Toronto. Train 26, the return HEP2 journey back from Ottawa to Quebec at ~2pm must be a different set with the same 2business 3economy configuration.
From looking at traincar.info, it seems that later in the week train 31 has a four car venture but no return trips to Montreal have only four cars. I suspect this means that there is just a blocked car on train 31 that is reopened in Ottawa.
Train 50 from Toronto to Ottawa was another 5 car HEP2 set. It had one business class car blocked until Ottawa and hence showed up as a 4 car set on train car.info
Do we have a visual on train 31? Ventures that look like one Business Class car is missing on traincar dot info are usually lighter-patronized trains with the normal six-unit length but only one Business Class car is used/staffed.
I believe it is a 5 car / 1 engine train with one business car unstaffed. That was what happened with train 50 today. I misinterpreted the train car.info site. Will amend my prior post.
Train 26 is confirmed a 5 car double ended HEP2 set. It has one unrefurbished car with the old red seats! I haven’t seen these since pre-Covid and thought they all gone ! Much more comfortable than the newer seats of the refurbished cars and all seats have a window!
No way. The LRC seats are much better
