News   Nov 29, 2024
 292     0
News   Nov 29, 2024
 179     0
News   Nov 29, 2024
 341     0
TTC: Streetcar Network
So true. From link.
Did you know that the reason for the Dundas Exhibition (later 193 Exhibition Rocket) streetcar to the Dufferin Gates, was because there was no Dufferin bus south of Bloor Street West before 1961.(See link.)
The 29 Dufferin bus only came into existence after July 1, 1954, and only between Wilson Avenue and Eglinton Avenue West (see link).
The 73 Dufferin South existed between 1961 and 1962, and only between St.. Clair Avenue West and Queen Street West. It would merge with the 29 Dufferin bus in 1962, and extended to the Dufferin loop. (See link.)
I've been finding the Dundas West streetcar loop behind the station to be deafening lately. Is there any way to submit a complaint or encourage more regular greasing? Any way to garner support for a sound barrier?
Winter. Can't use water.
The lubricate on the curves needs adjustment or repairs. When it rains or snows, the wheel squeal is reduced.
The subway curves into and out of Union Station and between Museum and St. George used to be deadening as well. Then they put water on the tracks and the noise got reduced. They use other lubricates these days. If they maintain it properly.
There is a complaint form on TTC website (link at bottom right corner of main screen - whether complaining will be of any use is another matter!
Complaining to the TTC will probably get you nowhere. Your councilor might get better results.
That may well be true but from my experience you MAY get more attention from a councillor if you have tried the 'normal routes" first and can say "The TTC never replied/did nothing/???"
What happens when ice meats hot steel wheels with friction?
From link.
Wheel squeal
Wheel squeal from rail transit operations is a common occurrence on rail lines around the world. TTC subway operations also produce wheel squeal. The frequency of this squeal noise can be a source of annoyance to our customers and to residents who live adjacent to our rail operations. The sensation of a frequency is commonly referred to as the pitch of a sound. People generally refer to the “high pitch” of the squeal.
Wheel squeal is caused by the steel wheel interacting with the top of steel rail and also by the interaction of the wheel’s flange with the side of the running and restraining rails. Most commonly, this squeal/screech occurs on curved sections of subway track. On some portions of the subway system, such as the curved tracks approaching Union Station, automatic wayside lubricators are used, and a specially formulated lubricant is applied to the side of the rails. The lubricators help to reduce noise levels but do not entirely eliminate the squealing sound. The lubricators are inspected regularly by track maintenance staff to ensure they are operating properly. However, from time to time, humidity levels and sudden temperature changes can reduce the effectiveness of the wayside lubricators.
Used on streetcar curves and, coming soon, to a light rail line curve near you.
Te new streetcars all have lubricating units on half the fleet either the odd numbered cars or the even numbered ones which are designed to apply a set amount of grease on the rails as they go b. When it rains though any existing lubricate is washed away and can take some time to build up again.
