Admiral Beez
I thought it was new infrastructure built next to new residences.We're talking about new infrastructure built next to existing residences, not the other way around.
The 504 King track dates from 19th century, some of the residences have been there for years, some are fairly new but the track-work at King & Sumach/Cherry (used by 514) is newer than any neighbouring homes.I thought it was new infrastructure built next to new residences.
And that's my point. These people bought new housing beside a new streetcar track, neither were there before.The 504 King track dates from 19th century, some of the residences have been there for years, some are fairly new but the track-work at King & Sumach/Cherry (used by 514) is newer than any neighbouring homes.
So that makes some kind of difference both were built at the same time. It doesn't mater which came first if you want to live near a streetcar loop or curve you should excpect some noise from it.And that's my point. These people bought new housing beside a new streetcar track, neither were there before.
As far as I know, the main problem area is at King/Sumach when streetcars are turning. The houses on the north side of King Street east of Sumach were built about a decade ago, the condo building on SE corner of King and Sumach was built about 5 years ago, the two houses on east side of Sumach just south of King are older. Then there are the homes on the 'stub' of Sumach just east of the portion of Sumach which has the tracks - they are from 19th century. The complaints seem to be about the squealing on the special-track-work at King and Sumach; ALL the homes in that area pre-date the construction (if not the planning) of the Sumach/Cherry streetcar track. That said, EastYorkTTCFan is right - one should be able to live beside a TTC track (of any age) and not have EXCESSIVE noise. The TTC can (and has) installed lubrication points (water or grease) to reduce squeal, they could do so here if other cheaper remedies fail.So that makes some kind of difference both were built at the same time. It doesn't mater which came first if you want to live near a streetcar loop or curve you should excpect some noise from it.
True enough.one should be able to live beside a TTC track (of any age) and not have EXCESSIVE noise. .
True enough.
There are some good points made here. The tracks are designed for the new streetcars, and the tracks are not "worked in".
The tracks are designed for STREETCARS. Until all of the old ones are gone, the track is built to a known standard that can handle both.
I'm not sure that I buy that the track needs to be "worked in" very much, either. A very lot of the curves through the intersection are flange-bearing, and will never get much more worn in than they are already. Unless they somehow think that the elastomeric coating of the rails will somehow soften over time.
It may be that the TTC has to bite the bullet and install flange greasers in the area.
The problem location that I see is where the the southbound cars have to make a sharp almost 90 degree turn onto the ROW coming off King St. Got to thank Transportation Department for this, as it wasn't what TTC wanted in the first place, but cars had to came first.The tracks are designed for STREETCARS. Until all of the old ones are gone, the track is built to a known standard that can handle both.
Maybe we should have gone to rubber wheels?
https://en.wikipedia.org/wiki/Rubber-tyred_trams
Bombardier makes it now https://en.wikipedia.org/wiki/Bombardier_Guided_Light_Transit
Might sound cheap n dirty, but what about laying down a bunch of tar. I mean like in every joint and alongside the rail. The vehicle will still be riding up on its flange, but no doubt it'd make less of a holler since the vibrations would be muffled some.
What's the physics of the noise -- is it coming primarily from the wheels, or the rail? If it's the former, a future solution might be to put some sort of dampers on the wheels, such as small rubber wheels that contact the flanges perpendicular to the wheel and dampen the vibration of the wheel itself (this likely could not be retrofit to the existing stock, however). If it's the rails, would resting them on some sort of more flexible rail bed or ties help?
