News   Apr 02, 2026
 2.3K     3
News   Apr 02, 2026
 1K     0
News   Apr 02, 2026
 2.6K     2
Transit Fantasy Maps
and since there hadn't been a station for 4 km, and nobody would build a metro system with that type of gap.
Haha
Interesting, because usually when rapid transit is proposed through the valley it takes the Leaside rail corridor. I like the Gatineau Corridor on your map better because it allows for stops at Thorncliffe and Flemingdon Park, dense priority neighbourhoods. The line also allows for potential interchanges with the Relief Line at both stops.
Ultimately, I don't see the Castle Frank problem to be too large when you consider the Relief Line's ability to interchange with both your proposed line and Line 2. Transit uses of this line or elsewhere in Scarborough with destinations along Line 2 simply adjust their commute pattern as needed.
I was thinking of likely 1 interchange with the DRL. Either at Throncliffe, it a route close to Overlea is chosen*, or another DRL station for Flemindon** for the interchange if a more southerly route is taken through Throncliffe.
* - I am assuming that with Presto the concept of a fair paid zone has little meaning, and this is acutally a transfer through the mall.
** - I am still a bit undecided about this station, which is also Science Centre South, since the Eglinton (Science Centre) station is not that far away.
The Kitchener Line should be further extended west to The Boardwalk (West End of K-W, huge residential area that would see a lot of usage), and maybe further into Stratford. Also, it would be cool if there was a west end line between Kitchener and Hamilton.
I am beginning to wonder if GO really needs to start running rail further than just the normal GTA. Places like London, Windsor, Kingston, Ottawa, and even some parts of Norther Ontario (Thunder Bay, Sudbury) could use commuter rail.
it reminds me of a NJ transit type thing.
