Interesting. I never really thought about trains having transmissions.
I was just digging to see what more I could find to post reference before answering Rob. The ZF mechanical gearbox has been discussed at length in this forum (IIRC?) a month or so ago. As to why it was chosen by Metrolinx and yet SMART *insisted* on the xmssn being all fluid coupling is a good question. SMART were paid by Metrolinx (a couple of hundred thousand $) to do the prototyping, but then decided to ignore some of it. There's still a torque converter before the ZF mechanical gearbox chosen, and it's a *six gear xmssn*! Sounds great in theory....and I think someone might have been intoxicated by the "green" claims for recovering that "lost (up to 20% worst case scenario) power in the all-fluid drive". Whatever, I will now post what I'd decided not to before, and keep looking on this. There's incredibly little published on this. More to come...
Felt like a 16 year old learning clutch for the first time.
Living right by the Bloor station, I can hear the shifting on the Sharyos. When it's good, it's very, very good. But when it isn't, you can hear it, and you're right, it's a lot like a trucker missing his shift....except with a mechanical xmssn, it's compounded by the number of vehicles in the consistent each finding their shift point at the same time. There's no fluid coupling to absorb the difference in RPM/load detection/and shift point parameter, it's all up to the electronic control systems. And like a computer, when they work well, they do wonders, but when it hiccups, you lose it all. Imagine for a moment two or three buses (the ZF xmssn used is essentially a bus one adapted for rail) rigidly coupled together, and expected to shift gears at exactly the same time.
Nice in theory, in practice, unless choreographed/synched, it ain't gonna happen. Things will break.
A quick Edit to Add that I may have to retract. I'll try and reference this later pro or con.
Since the 'grand plan' is to butcher the Sharyos and give them a sex-change into EMU from DMU 'as easy as pie' (if you believe the propaganda sheets Sumitomo and Metrolinx used to publish) when the Weston Corridor is electrified, the engines, bogies and a lot of ancillaries are to be removed in a 'modular fashion' and replaced by electrics. (Talk about compounding the inherent design weaknesses). One of the pluses of this will be, ostensibly, since the bogies are to be replaced, bogies with the electric traction motors bogie mounted, a much more efficient and *better tracking* bogie with greater tractive factors (in almost all cases. You want your weight right on the tractive surfaces) and they ride, in almost all cases, if well designed, much better and consistently too. No Cardan shaft!
So here's a wild proposal for Metrolinx: If you're going to electrify at some point anyway, order those bogies now, and add a generator to the Cummins prime motor. Forget fluid and/or mechanical coupling. Will this be buggy? Quite likely initially, but no more so than being totally electrified, and certainly no more so than now. So perhaps it's time to consider going the DEMU route, and even before full electrification, let alone full route flexibility after to allow these units to run on the outer regions of the network, start the conversion now.
So what about the insertion loss of electric gen to electric drive? No more so than mechanical losses, especially if those mechanics aren't working as they should.
I need more reference to comment further, but Metrolinx is facing crunch time with those units, and they need to know whether to buy in any more (at twice the price of initial purchase) or cut their losses and adapt them.
Edit to Add, Tues 11:00 AM:
Note the British Rail Class 220, and related variants, use the same engine as the Sharyos (albeit not the R version, which is the exhaust treatment for Tier 4 compliance, but same rated power output) but have a gen set driven by the engine which then drives traction motors:
All
coaches are equipped with a
Cummins QSK19
diesel engine of 750
hp (560
kW) at 1800
rpm. These power a
generator which supplies
current to motors driving two axles per coach,
[6] with one axle per bogie powered.
[7][8]
Maximum speed 125 mph (200 km/h)
https://en.wikipedia.org/wiki/British_Rail_Class_220
Many factors might come into play realizing that performance, but I'm puzzled as to how Bombardier got that performance 16 years ago that the Sharyos can only match with a mechanical xmssn today that ostensibly "is more efficient by eliminating transmission losses".
These are also Cardan shaft driven, but the latest bogie designs have radically reduced weight and increased ride and tracking performance, with bogie mounted traction motors that can be run either EMU or DEMU.
This may all seem a solution for a problem that doesn't exist...except a problem does exist: Even if the Sharyos were performing well, the cost has doubled to buy more, and there's not enough of them at present to do the RER function of the existing Bramalea-Union Corridor on a fifteen minute headway. As Paul mentions, perhaps increasing that to 20 mins might make it work? It's still a stretch, but something has to give.
The most obvious solution if the problems we're hearing about are true is to sell them. But there is no market. UPX jumped in too fast on these, the regs for this type of system in North Am is changing fast, and we're going to have all sorts of options of European type models available to use at some point in the near future.
So we're probably stuck with the Sharyos. We'd best start looking at re-purposing them now, and utilize that to address the alleged (albeit unproven, but anecdotal logic indicates this to be the case) problems. We're still waiting for funding and a fixed date for electrifying that corridor, so a DEMU conversion looks very opportune in the meantime.
